December 13, 2021, 17:44 |
Floating Point Error Using AMI
Will
Rep Power: 4 |
I'm new to using the AMI feature on OpenFoam and I am having trouble running my mesh. I can create the mesh fine using snappyHexMesh but when I try to run the case using simpleFoam, the case fails on the first iteration and gives me a floating point exception. I've also tried converting the case over to pimpleFoam and the case still fails. I have attached my case files. Any Help is much appreciated! |
December 15, 2021, 16:37 |
Will
Rep Power: 4 |
I figured out my issue, the weights on my AMI surface were at 0 so I modified my SHM so that they weren't. The sim started running after that.
Here is the thread that helped me resolve the issue. Periodic cyclic AMI + MRF crashing on pressure |
ami, dynamicmesh error, openfoam |
Error running AMI propeller simulation | luitzor | OpenFOAM Running, Solving & CFD | 0 | April 19, 2021 13:48 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
[snappyHexMesh] snappyHexMesh and cyclic boundaries | Ruli | OpenFOAM Meshing & Mesh Conversion | 2 | December 9, 2013 06:51 |
pimpleDyMFoam constantly giving floating point exception and solution divergence | fedvasu | OpenFOAM Running, Solving & CFD | 0 | November 28, 2013 00:53 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
