September 4, 2021, 07:07 |
Decomposing domain
Rep Power: 5 |
I have a divergent duct in Openfoam. I simulate it with 20 processors. I need to increase inlet pressure successively during the simulation. For example after 0,5ms. I will increase the inlet pressure. How should I realise it? Should I go to the 0.005 folder and change the pressure inside this folder and then decompose the domain again. Or should I go to the each processor files and change the pressure inside each processor files? For the second option I think I would not need to decompose the domain again . Your help will be appreciated! Thanks |
September 4, 2021, 12:19 |
Rep Power: 14 |
There are time-varying boundary conditions that will change it for you, so the manual editing isn't necessary! The first that comes to mind is uniformFixedValue, using a table to specify how you want the value to change with time. So it'd look something like :
type uniformFixedValue; uniformValue table ( (0 100000) (0.005 200000) //replace with desired value(s) ); value $internalField; Caelan
Public git repository : https://github.com/clapointe2011/public |
September 4, 2021, 15:55 |
#3 | |
Rep Power: 5 |
Thanks a lot for the reply
I use at the inlet total pressure boundary condition. So I changed the boundary condition at the inlet as follows: Code:
inlet { type uniformTotalPressure; rho rho; psi none; gamma 1.4; p0 table ( (0 130000) (0.0007 170000) (0.0014 210000) (0.0021 260000) (0.0028 310000) (0.0035 460000) (0.0042 410000) (0.0049 460000) (0.0056 51000) (0.0063 560000) (0.0070 610000) (0.0077 660000) (0.0084 710000) (0.0091 760000) (0.0098 800000) ); ; } Quote:
Thanks in advance! |
September 4, 2021, 16:05 |
Rep Power: 14 |
That appears to work for the version of openfoam I referenced (e.g. example case), so I'd guess that it will depend on the version... I found the linked case with a quick search of the available tutorials, so it'd be worth doing the same for the version you're using.
Caelan
September 4, 2021, 17:04 |
Rep Power: 5 |
Thanks. I use Openfoam 2.1.1, which is a very old version. I cant find any information about my question for this version |
September 5, 2021, 11:58 |
Rep Power: 14 |
A quick search of 2.1.x shows that (presumably) the same tutorial also uses a table in the bc : tutorial. So at a glance it looks like the same functionality is available -- it just expects a slightly different format.
Caelan
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
Can I achieve better convergence? | sheaker | CFX | 12 | September 19, 2019 15:36 |
Turbomachinery Mass imbalance | sheaker | CFX | 12 | September 5, 2019 08:09 |
Closed Domain Buoyancy Flow Problem | Madhatter92 | CFX | 6 | June 20, 2016 21:05 |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 04:59 |
