version 9 betav betavsolid removed what is the replacment? |
September 5, 2021, 06:01 |
Derek Mitchell
Rep Power: 13 |
In previous versions in chtMultiRegionFoam solvers there was a field betavSolid which sets betav inthe energy equation which enable one to scale the conductivity for a particular set of cells which I have been using for the last 5 years. This has been removed in version 9. In version 9 how does one do the same i.e. set non homogenous conductivity within a region?
I have noticed there is a lot entries for heat transfer in fvModels is the solution there?
A CHEERING BAND OF FRIENDLY ELVES CARRY THE CONQUERING ADVENTURER OFF INTO THE SUNSET |
"Temperature out of range" Problem with reactingFoam | altinel | OpenFOAM Running, Solving & CFD | 6 | December 28, 2023 12:53 |
FOAM FATAL ERROR: Continuity error cannot be removed by adjusting the outflow | Roesch | OpenFOAM Running, Solving & CFD | 1 | May 7, 2022 09:34 |
different results form openfoam 3.0.1 to 1912 | yuno | OpenFOAM Running, Solving & CFD | 0 | September 28, 2020 03:09 |
OpenFOAM-1.6 install cookbook | MadsR | OpenFOAM Installation | 372 | November 20, 2010 11:57 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
