no sets folder in postProcessing, so I can't create streamlines |
February 15, 2022, 16:22 |
Alan w
Rep Power: 6 |
Previously, I successfully ran a chtMultiRegion case in which I could view streamlines by opening up a postProcessing/sets file in paraView.
I then used this case as a template for another case, but this time it isn't creating the sets folder, and for the life of me, I can't figure out why. In the first case, under the postProcessing folder were these folders: - cuttingPlane - fluid - sets But in the second case, under postProcessing are: - bod - fieldsMinMax - forceCoeffs1 - yPlus During the run log, it says: streamLine streamLines write: seeded 0 particles Tracks:0 Total samples:0 So something is not right. But I have #include "streamLines" in the controlDict, and the 'streamLines' file in the system folder. Attached are the controlDict, streamLines and run output files. If more are needed, please let me know. Why isn't the 'sets' folder with associated streamline data being created? |
February 24, 2022, 11:55 |
still have this issue; here is more info
Alan w
Rep Power: 6 |
In my experience (admittedly limited), I find that the native openFoam streamline function is way better than the paraView streamtracer. But in the case I am currently working, it is stubbornly refusing to execute. It is not creating a 'sets' folder with vtk data for streamlines under 'postProcessing'. In the run output, at the bottom it says that no particles are being seeded:
Build : 9-b456138dc4bc Exec : simpleFoam -parallel Date : Feb 23 2022 Time : 11:11:58 Host : "boffin5-VirtualBox" PID : 43733 I/O : uncollated Case : /home/boffin5/cfdaero/meredith-flow9 nProcs : 2 Slaves : 1("boffin5-VirtualBox.43734") Pstream initialised with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMas ter (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: No convergence criteria found Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kOmegaSST Selecting patchDistMethod meshWave RAS { model kOmegaSST; turbulence on; printCoeffs on; alphaK1 0.85; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.856; gamma1 0.555556; gamma2 0.44; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; b1 1; c1 10; F3 false; } No MRF models present No fvModels present No fvConstraints present Starting time loop Reading surface description: yNormal forces forceCoeffs1: Not including porosity effects forceCoeffs forceCoeffs1: Not including porosity effects streamlines streamLine1: automatic track length specified through number of sub cycles : 5 forceCoeffs forceCoeffs1 write: Cm = 0.00432683 Cd = 0.0532299 Cl = -0.000247849 Cl(f) = 0.0042029 Cl(r) = -0.00445075 total used free shared buff/cache available Mem: 2025216 1022456 363124 14760 639636 828756 Swap: 2097148 848924 1248224 total used free shared buff/cache available Mem: 2025216 1022716 362864 14760 639636 828496 Swap: 2097148 848924 1248224 streamlines streamLine1 write: seeded 0 particles Tracks:0 Total samples:0 Time = 1 Code:
FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application simpleFoam; startFrom latestTime; startTime 0; stopAt endTime; //endTime 2000; endTime 200; deltaT 1; //deltaT .001; writeControl timeStep; writeInterval 50; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; functions { //#include "streamLines" #include "cuttingPlane" #include "forceCoeffs" /*FieldsMinMax // monitor { type fieldMinMax; functionObjectLibs ("libfieldFunctionObjects.so"); enabled true; mode component; writeControl timeStep; writeInterval 5; // output every 5 time steps, change as needed log true; fields (p U k); // list of any fields you want to monitor }*/ FreeMemorySystemCall // memory { type systemCall; libs ("libutilityFunctionObjects.so"); executeCalls (); writeCalls ("free"); endCalls (); writeControl timeStep; writeInterval 50; // Set the interval as required } bod { log no; enabled yes; type forceCoeffs; functionObjectLibs ( "libforces.so"); patches (bod); rho rhoInf; rhoInf 1.058; //porosity no; CofR ( 0 0 0); liftDir ( 0 0 1); dragDir ( 1 0 0); pitchAxis ( 0 1 0); magUInf 56.589; // meters per second lRef 1; Aref 1; writeControl timeStep; writeInterval 1; } yplus { type yPlus; functionObjectLibs ("libfieldFunctionObjects.so"); enabled true; writeControl outputTime; } streamlines { type streamlines; // Where to load it from (if not already in solver) libs ("libfieldFunctionObjects.so"); // Output every writeControl writeTime; // writeInterval 10; setFormat vtk; // gnuplot;//xmgr;//raw;//jplot;//csv;//ensigh t; // Track forward (+U) or backward (-U) or both direction forward; // Names of fields to sample. Should contain above velocity field! fields (U); //fields (p k U); // Steps particles can travel before being removed lifeTime 10000; // Number of steps per cell (estimate). Set to 1 to disable subcycl ing. nSubCycle 5; // Cloud name to use cloudName particleTracks; // Seeding method. seedSampleSet { type lineUniform; axis x; // distance; start (1.2 0.1 0.0); end (1.2 0.1 0.2); nPoints 20; } } } |
Meshing a Sphere | Ajay | FLUENT | 10 | September 3, 2016 14:18 |
Creating and postprocessing a rotational surface | paul_mathis | OpenFOAM Post-Processing | 2 | July 13, 2009 04:09 |
Postprocessing - Create JPEG's without GUI. | Frank D. | FLOW-3D | 1 | January 9, 2009 00:06 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
How to create postprocessing planes in Gambit | kyaw kyaw | FLUENT | 2 | April 23, 2007 17:16 |
