Coupled heat transfer convective-diffusive
Old   October 12, 2021, 09:17
Default Coupled heat transfer convective-diffusive
Léo BAZIN
leobaz is on a distinguished road
Hello everyone,
I'm writting this post because I need to simulate a flow heated by an obstacle in the center of the flow in 2D axis-symetric. I already used BuoyantBoussinesqSimpleFoam to simulate the mixing between a hot flow with a cold one, so I decided to keep using this solver. However, results show that the only heat transfer taken into account is the diffusive heat transfer, as you can see on pictures attached. The heat is not transported by the flow.
I used fixedGradient BC but I also tried with fixedValue and the conclusion remains the same.
|  \\    /   O peration     | Version:  v2012                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 673;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 673;
    outlet
        type            zeroGradient;
    wall
        type            zeroGradient;
	obstacle
        type            fixedGradient;
		gradient		uniform 500;
    wedge0
        type            wedge;
    wedge1
        type            wedge;
I can provide other files of course but I wonder if the problem is not about the solver itself.
So my questions are : - Can we use BuoyantBoussinesqSimpelFoam to solve this type of problem ?
- Is there some options available to enable convection heat transfer in buoyant(Boussinesq)SimpleFoam ?
- Do I have to use chtMultiRegionFoam and model the heater/obstacle as a solid ?
Regards,
Léo.
leobaz is offline   Reply With Quote
convective heat transfer, coupled heat transfer
Convective heat transfer coefficient huizju OpenFOAM Running, Solving & CFD 0 July 7, 2020 07:25
Convective Heat Transfer Validation csaban CFX 5 May 12, 2020 18:37
Surface Heat Transfer Coefficient driven by a UDF, using coupled wall ryanbezz11 CFD Freelancers 1 March 16, 2018 03:01
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 17:30
Fifth order anti diffusive scheme for 1D hyperbolic heat transfer areffallah Main CFD Forum 0 November 3, 2010 04:48
