chtMultiRegionFoam is slower in parallel than serial |
September 11, 2023, 15:41 |
Roberto
Rep Power: 4 |
Hi All,
I am trying to run a multi region case in parallel. However, it runs slower in parallel than serial. So, I went back to the tutorial case multiRegionHeater (within heatTransfer/chtMultiRegionFoam) and I ran it both in serial and parallel. The parallel run is slower than the serial run. I have also tried other tutorial cases with buoyantPimpleFoam and solidFoam and I was able to run them in parallel, and their performance is better than the serial run's. Anyone any ideas? How can I make chtMultiRegionFoam run faster in parallel. Thanks, Roberto P.S. I am using OpenFoam-v2012. |
September 12, 2023, 13:55 |
Roberto
Rep Power: 4 |
Thanks dlahaye for your response.
You are right. I have increased the number of volumes in the tutorial example, and now the parallel case runs faster than the serial. Thanks for the help! |
chtmultiregionfoam, parallel |
different results between serial solver and parallel solver | wlt_1985 | FLUENT | 11 | October 12, 2018 08:23 |
Error running openfoam in parallel | fede32 | OpenFOAM Programming & Development | 5 | October 4, 2018 16:38 |
To continue from latestTime of a previous serial run in parallel | redbullah | OpenFOAM | 2 | July 26, 2018 14:01 |
Parallel vs Serial Run-Solver manager | rohit_turbo | CFX | 5 | March 4, 2016 08:34 |
MPI slower than serial | LucaFen | OpenFOAM Running, Solving & CFD | 0 | November 24, 2015 06:08 |
