Combining multiSolidBodyMotionSolver (Overset Mesh) + SolidBodyDisplacementLaplacian |
October 26, 2021, 05:58 |
Ege Batmaz
Rep Power: 7 |
Dear Foamers,
I am trying to conduct a simulation where I need to morph the shapes of multiple airfoils while they are rotating on a stationary region (The mesh around the airfoil must rotate with the airfoil for a reason so I need to achieve this with overset mesh/rotating motion). I've already achieved shape morphing with overset mesh when there is no overset mesh rotation but things are getting more complicated when there is overset mesh motion. So I need to use dynamicOversetFvMesh with 2 different solvers simultaneously: multiSolidBodyMotionSolver (For overset mesh rotation of airfoils) and solidBodyDisplacementLaplacian (For the shape morphing of airfoils). Do you have any suggestions on how to achieve this? I used to achieve Sliding(Rotating) mesh + Morphing without overset mesh with dynamicMultiMotionSolverFvMesh. But now this is not the case, where I need to stick with the dynamicOversetFvMesh to able to compute overset mesh motion. PS: I am using OpenFOAM v1706. Thank you for your time. Best Regards, Ege |
September 16, 2022, 15:30 |
suyash
Rep Power: 7 |
Hi Ege,
Were you able to figure out the way for your problem?. The issue is actually addressable in OpenFOAM-v1912 and the following versions, however I notice a bug that keeps updating the overset mesh to its default (t_0) position, at every alternate time step. Please let me know if you or anyone has any experience with this issue. Thanks |
January 2, 2023, 08:10 |
#3 | |
TWB
Rep Power: 19 |
Do you have an example of your setup? Maybe we can take a look and see how to troubleshoot... |
March 3, 2023, 04:38 |
Georg Göbel
Rep Power: 9 |
Dear Ege,
have you been succesful in combining overset with morphing? I am trying to do so at the moment but as far as I understand, the use dynamicOversetFvMesh AND dynamicMotionSolverFvMesh is not possible. If you or anyone else solved this issue, i would aprecciate if you could share your dynamicMeshDict. Thanks in advance! Georg |
September 12, 2023, 21:38 |
#5 | |
xiangxiang
Rep Power: 3 |
Have you combined overset and morphing? I used precice to couple calculix and openfoam. In my case, the fluid-to-structure interface of the front mesh was deformed, and the displacement was derived from calculix calculation. Now the non-overset mesh was fine, but the overset mesh would report errors. This seems to be consistent with the explanation in foam extend: “ Direct application of overset mesh would result with deformation of both background and front mesh”. Do you have any modification suggestions? |
dynamicmesh, dynamicoverset, multisolidbodymotion |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
Overset simulation fails when using 2 close together overset + background mesh | quarkz | OpenFOAM Running, Solving & CFD | 0 | January 7, 2021 02:36 |
Is overset mesh required? | ahildershavn@yahoo.no | OpenFOAM Running, Solving & CFD | 2 | August 4, 2017 03:23 |
Overset: refine background mesh without resetting the mesh | JohnAB | STAR-CCM+ | 6 | May 19, 2014 13:48 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
