Effective thermal conductivity chtMultiRegionSimpleFoam
Old   November 6, 2021, 04:09
Default Effective thermal conductivity chtMultiRegionSimpleFoam
Derek Mitchell
derekm is on a distinguished road
In the standard solid energy equation betav scales the thermal diffusivity
and if betav is great than one the energy moving through the medium increases
To model a porosity in fluid I use fvOptions explicitPorositySource to cater for the momentum. I modified the fluid energy equation to make it similar to the usage of betav i.e betaw in the lapacian term. This is to enable varying the effective conductivity of the fluid. But if betaw is greater than 1 the energy flow through the medium decreases. Why is this the opposite effect to the solid ?????
modified solver and case file attached OpenFOAM version 4.x
Modified file: UchtMultiRegionSimpleFoam/fluid/EEqn.H betaw multipler is the only modification
    volScalarField& he = thermo.he();
    fvScalarMatrix EEqn
        fvm::div(phi, he)
            he.name() == "e"
          ? fvc::div(phi, volScalarField("Ekp", 0.5*magSqr(U) + p/rho))
          : fvc::div(phi, volScalarField("K", 0.5*magSqr(U)))
      - fvm::laplacian(betaw*turb.alphaEff(), he)
        rho*(U&g)
      + rad.Sh(thermo)
      + fvOptions(rho, he)
    EEqn.relax();
    fvOptions.constrain(EEqn);
    EEqn.solve();
    fvOptions.correct(he);
    thermo.correct();
    rad.correct();
    Info<< "Min/max T:" << min(thermo.T()).value() << ' '
        << max(thermo.T()).value() << endl;
unchanged Solid file:UchtMultiRegionFoam/UchtMultiRegionSimpleFoam/solid/solveSolid.H
    for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
        fvScalarMatrix hEqn
                thermo.isotropic()
              ? -fvm::laplacian(betav*thermo.alpha(), h, "laplacian(alpha,h)")
              : -fvm::laplacian(betav*taniAlpha(), h, "laplacian(alpha,h)")
            fvOptions(rho, h)
        hEqn.relax();
        fvOptions.constrain(hEqn);
        hEqn.solve();
        fvOptions.correct(h);
thermo.correct();
added code in file: UchtMultiRegionFoam/UchtMultiRegionSimpleFoam/fluid/createFluidFields.H
PtrList<volScalarField> betawFluid(fluidRegions.size());
   // betawFluid mod start
    Info<< "    Adding to betawFluid\n" << endl;
      IOobject betawFluidIO
            "betawFluid",
            runTime.timeName(),
            fluidRegions[i],
            IOobject::MUST_READ,
            IOobject::AUTO_WRITE
        if (betawFluidIO.headerOk())
             Info<< "    reading betawFluid file \n" << endl;
            betawFluid.set
                i,
                new volScalarField(betawFluidIO, fluidRegions[i])
        else
            Info<< "    reading all betawFluid as 1.0 \n" << endl;
            betawFluid.set
                i,
                new volScalarField
                    IOobject
                        "betawFluid",
                        runTime.timeName(),
                        fluidRegions[i],
                        IOobject::NO_READ,
                        IOobject::NO_WRITE
                    fluidRegions[i],
                    dimensionedScalar("1", dimless, scalar(1.0))
        //betawFluid mod end
added line in UchtMultiRegionSimpleFoam/fluid/setRegionFluidFields.H
const volScalarField& betaw = betawFluid[i];
A CHEERING BAND OF FRIENDLY ELVES CARRY THE CONQUERING ADVENTURER OFF INTO THE SUNSET
derekm is offline   Reply With Quote
effective thermal conductivity and mass weighted thermal conductivity Weiqiang Liu FLUENT 8 June 19, 2020 00:08
Question about anisotropic thermal conductivity Szweyk STAR-CCM+ 2 June 30, 2016 08:26
Thermal conductivity issue Jared1986 CFX 3 March 20, 2014 10:38
IAPWS water properties + orthotropic thermal conductivity Chander CFX 1 February 29, 2012 17:26
Porous Media Effective Thermal Conductivity Greg Perkins FLUENT 3 August 5, 2001 21:53
