Always diverging on second timestep, no matter from where it begins |
November 11, 2021, 15:34 |
Julio Pieri
Rep Power: 8 |
Dear Foamers,
I'm facing a very weird and enigmatic behavior in my transient twoPhaseEulerFoam simulation of a fluidized bed. I'm using OF v2012, and got the same result with v1812, both on WSL Ubuntu. I've been working on a series of similar cases for over 4 months now, and I have had pretty good results so far. During a power shortage the other night, some cases stopped running on the server after 7.45s of simulation (it took 3 days to get to this point, hence why I want to solve this issue). This have happened before and I could easily restart them. However, this particular setup won't restart, always diverging on the second time iteration - no matter if I deleted one, two, ten, whatever, latest timesteps. Smaller timesteps also didn't help. I've created a simple case that reproduces this. If I leave it be, fresh start, it runs smoothly with no problems. If I interrupt it anywhere, though, it doesn't restart. Even stranger: if I write every timestep calculated, I can advance with the solution: it writes the first iteration -> diverges on second tstep -> I resume it -> it writes one more -> diverges again, etc. Looking at paraview, the solution evolves as I would expect, suggesting the setup is ok. The error is the following: Code:
PIMPLE: iteration 1 MULES: Solving for alpha.particles MULES: Solving for alpha.particles smoothSolver: Solving for alpha.particles, Initial residual = 3.29388e-06, Final residual = 2.35206e-10, No Iterations 1 alpha.particles volume fraction = 0.31103 Min(alpha.particles) = 0 Max(alpha.particles) = 0.600047 Constructing momentum equations #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in /lib/x86_64-linux-gnu/libpthread.so.0 #3 Foam::tmp<Foam::GeometricField<Foam::typeOfMag<Foam::Vector<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::mag<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #4 Foam::phasePair::magUr() const at ??:? #5 Foam::phasePair::Re() const at ??:? #6 Foam::heatTransferModels::RanzMarshall::K() const at ??:? #7 Foam::BlendedInterfacialModel<Foam::heatTransferModel>::K() const at ??:? #8 Foam::twoPhaseSystem::Kh() const at ??:? #9 ? at ??:? #10 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 #11 ? at ??:? Floating point exception Code:
Foam::tmp<Foam::volScalarField> Foam::phasePair::magUr() const { return mag(phase1().U() - phase2().U()); } If I change the Heat Transfer Model from RanzMarshall to the other available, called spherical, the error changes and get closer to what I believe might be related to the cause: Code:
PIMPLE: iteration 1 MULES: Solving for alpha.particles MULES: Solving for alpha.particles smoothSolver: Solving for alpha.particles, Initial residual = 3.44837e-06, Final residual = 2.4905e-10, No Iterations 1 alpha.particles volume fraction = 0.31103 Min(alpha.particles) = 0 Max(alpha.particles) = 0.600048 Constructing momentum equations smoothSolver: Solving for e.particles, Initial residual = 8.98554e-08, Final residual = 2.86103e-08, No Iterations 1 smoothSolver: Solving for e.air, Initial residual = 0.0395403, Final residual = 3.89446e-07, No Iterations 2 min T.particles 1122.95 min T.air 426 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in /lib/x86_64-linux-gnu/libpthread.so.0 #3 Foam::scalarProduct<double, double>::type Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam::PCG::scalarSolve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #5 Foam::GAMGSolver::solveCoarsestLevel(Foam::Field<double>&, Foam::Field<double> const&) const at ??:? #6 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? #7 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #8 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? #9 Foam::fvMatrix<double>::solveSegregatedOrCoupled(Foam::dictionary const&) at ??:? #10 Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const at ??:? #11 ? at ??:? #12 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 #13 ? at ??:? Floating point exception Code:
export FOAM_SIGFPE=false Code:
[...] at second timestep: Constructing momentum equations smoothSolver: Solving for e.particles, Initial residual = 8.98554e-08, Final residual = 2.86103e-08, No Iterations 1 smoothSolver: Solving for e.air, Initial residual = 0.0395403, Final residual = 3.89446e-07, No Iterations 2 min T.particles 1122.95 min T.air 426 GAMG: Solving for p_rgh, Initial residual = 1, Final residual = nan, No Iterations 1000 GAMG: Solving for p_rgh, Initial residual = nan, Final residual = nan, No Iterations 1000 So far, what I've tried:
I've tried eveything I can think of, and I can't manage to overcome the problem. I believe I might be close to a possible OF bug: this might be a very very specific set of parameters - mesh, timescale, velocity, phase fraction, etc - that makes the solver go crazy. Remember, I've had several other successful cases running with very similar parameters. And if I fresh start it, it goes well!! The difference from this case to the last one that was ok is that this one have a slightly smaller domain (same element size). Attached you can find the compressed case (zip or tar). To reproduce the error, hit Allrun, stop after it writes the first timestep (0.001s), then hit "twoPhaseEulerFoam" to restart it. You can change the heat transfer model inside constant/phaseProperties. Any help or insight is welcome. Thank you very much! |
diverging, ranzmarshall, second timestep, sigfpe, twophaseeulerfoam |
Adjustable timestep for settleling, then fixed timestep large eddy simulation | stud-many | OpenFOAM | 1 | June 15, 2021 23:09 |
Cfx initial time choice for adaptive timestep | butterflymuzzy | CFX | 7 | April 22, 2021 19:05 |
Understanding Log Output / InitialResidual / Adjust timestep | betelgeuze | OpenFOAM Running, Solving & CFD | 4 | November 7, 2020 13:26 |
error with smaller timestep ? | Thomas MADELEINE | FLUENT | 0 | August 8, 2016 13:02 |
Modeling new matter! | Sunil Hadap | Main CFD Forum | 2 | February 23, 2000 17:06 |
