Possibility to perform two simple.loop inside the same code |
August 23, 2018, 17:05 |
Pablo Alarcón
Rep Power: 8 |
Good morning everybody
I would like to know if it is possible to perform two simple.loop inside the same code. In simplified words, what I want to do is something like this algorithm Code:
int main(...) { while(it <= maxIter) { ... while (simple.loop()) // first loop { ... #include "UEqn.H" #include "pEqn.H" ... } ... while (simple.loop()) // second loop { ... #include "UEqn2.H" #include "pEqn2.H" ... } ... } ... } My guess is that happens because simple.loop already have an stop signal recorded, so when I try to enter the second loop by means of while (simple.loop()) for the second loop, simply doesn't enter because the while(simple.loop()) condition was already fulfilled in the first loop. Is there any way to restart or put to zero the simple.loop in order to be able to enter to the second loop? Any insight, references to documentation or examples, or threads in the forum I may have missed are welcome. |
[isoAdvector] Issues with modification of IsoAdvector Code | raunakbardia | OpenFOAM Community Contributions | 16 | September 4, 2020 05:36 |
possibility to perform two simple.loop inside the same code | palarcon | OpenFOAM Programming & Development | 5 | August 28, 2018 09:48 |
Type mismatch: Assigning a scalar to a Field<Type> inside templated BC code | karlli | OpenFOAM Programming & Development | 2 | August 28, 2017 01:25 |
public CFD Code development | Heinz Wilkening | Main CFD Forum | 38 | March 5, 1999 11:44 |
What kind of Cmmercial CFD code you feel well? | Lans | Main CFD Forum | 13 | October 27, 1998 10:20 |
