Possibility to perform two simple.loop inside the same code
Old   August 23, 2018, 17:05
Default Possibility to perform two simple.loop inside the same code
Pablo Alarcón
palarcon is on a distinguished road
Good morning everybody
I would like to know if it is possible to perform two simple.loop inside the same code. In simplified words, what I want to do is something like this algorithm
int main(...)
while(it <= maxIter)
     while (simple.loop())     // first loop
          #include "UEqn.H"
          #include "pEqn.H"
     while (simple.loop())     // second loop
          #include "UEqn2.H"
          #include "pEqn2.H"
The problem is that when I code like that, the solver enter the first loop and solve the flow but then doesn't enter the second loop.
My guess is that happens because simple.loop already have an stop signal recorded, so when I try to enter the second loop by means of while (simple.loop()) for the second loop, simply doesn't enter because the while(simple.loop()) condition was already fulfilled in the first loop.
Is there any way to restart or put to zero the simple.loop in order to be able to enter to the second loop?
Any insight, references to documentation or examples, or threads in the forum I may have missed are welcome.
palarcon is offline   Reply With Quote
Old   August 25, 2018, 14:08
Peter Baskovich
pete20r2 is on a distinguished road
I'm not too strong on c++ and I don't have the source in front of me but I'd say that you are right and the second loop doesn't run because the simple.loop() function is returning 0. I think you should reconsider what exactly you are doing because solving the simple loop again is equivalent to just lowering the solver tolerances so it loops more in the first place. You won't be working on the results of the first simple loop until the timestep (iteration for steady state) is advanced.
pete20r2 is offline   Reply With Quote
Old   August 26, 2018, 16:46
clapointe is on a distinguished road
If you aren't using the simple controls (ie just running for a fixed number of iterations) a simple fix is to use your own for or while loops instead of simple.loop().
Caelan
clapointe is offline   Reply With Quote
Old   August 27, 2018, 04:13
Pablo Alarcón
Actually and in principle, I need the simple controls (or an equivalent one) because is necessary to converge the flow equations in loop 1 before entering loop 2, which, unfortunately solve equations that are really similar. That is the reason why I'm using simple.loop in both.
Old   August 27, 2018, 04:43
Pablo Higuera
Phicau is on a distinguished road
Hi Pablo,
how about re-defining the variable simple? You can try adding this line after the first loop has finished:
simpleControl simple(mesh);
I cannot test it right now, but I imagine that in order for it to work, the variable startFrom in controlDict needs to be set to startTime, and startTime to the value of your starting time, usually 0.
Best,
Pablo
Check out my new project: olaFlow --> The olaFlow Support Thread
Phicau is offline   Reply With Quote
Old   August 27, 2018, 10:05
Another option would be to manually set the time with eg. runTime.setTime() -- you'd set it to zero. I think this would reset the simple controls.
Caelan
Old   August 28, 2018, 01:11
Peter Baskovich
You could have a look at how the chtMultiRegionFoam handles multiple meshes and solver loops. It appears to setup custom loops for the different regions neatly.
Old   August 28, 2018, 03:10
Pablo Alarcón
Hello
Everybody, I'm taking notes of all of your comments and I will try them today.
Old   August 28, 2018, 03:18
Pablo Alarcón
Hello Phicau
Can you please explain me the effect of
It will reset the convergence criteria, the number of iteration or something different?
Old   August 28, 2018, 03:21
Pablo Alarcón
Caelan
I tried that and it "worked" but not perfectly
runTime.setTime(it - 1,it -1);
The idea is that after completing the computation of the loop 1 (with N inner iterations) must enter the second loop, where the inputs are the results of the first loop.
That is the reason why the counter is reset to the value of the global iteration number, because there should be X number of complete solutions of the flow (because loop 2 changes the topology of the design domain).
Old   August 28, 2018, 03:29
Pablo Higuera
Originally Posted by palarcon View Post
Hello Phicau
It will make it have the same value it had when the simulation started. Basically it is the line called by the solver to initialize the object simple.
Old   August 28, 2018, 09:45
Pablo Alarcón
Hi Pablo
Unfortunately that option doesn't work
error: redeclaration of ‘Foam::simpleControl simple’
Originally Posted by Phicau View Post
Hi Pablo,
Best,
Pablo
Old   August 28, 2018, 21:26
Pablo Higuera
I see... what about using another variable name?
simpleControl simpleSecond(mesh);
while (simpleSecond.loop())     // second loop
Old   August 28, 2018, 22:00
I see. How many of the outer iterations are you doing? If the secondSimple from above doesn't work, then another option will be to set to zero and then write to zero. Then you'll be at "zero" time but with the data from the previous simple loop.
Caelan
Old   August 30, 2018, 05:14
Pablo Alarcón
Do you have any idea on how create that second variable simpleSecond.loop in order to be recognized by OpenFOAM?
Old   August 30, 2018, 05:15
Pablo Alarcón
I can set the time to zero (or any number) but that doesn't change the convergence criteria.
If the first loop is already converged, then there is no way on entering into the second, that is the reason why I have to reset the convergence criteria and not only the time value.
Caelan
Old   August 30, 2018, 11:02
Good point -- I was hoping that writing in addition to changing the time would help. Should have looked at the code first.
What if you just wrote your own conversion criteria? Use two while loops, and when whatever you decide to calculate stops changing, you're converged.
Caelan
Old   August 30, 2018, 21:13
Pablo Higuera
Hi Pablo
the way to define the second variable is easy:
I presume that it will need to have the following lines in your controlDict for it to work properly:
startFrom startTime;
startTime 0;
Pablo
Old   June 29, 2020, 05:11
Jesús Miguel Sánchez
Jesus.M is on a distinguished road
Did the last solution work?
Jesus.M is offline   Reply With Quote
Old   November 15, 2021, 02:22
Post
  #20
JHopman
Jansois is on a distinguished road
Not sure if it has already been solved but this works for me.
Add an extra constructor for another pimpleControl object in your solver:
pimpleControl pimple(mesh);    //normal line
pimpleControl pimple2(mesh, "PIMPLE2", true);    //added line
Then you can create additional loops in your solver with:
while (pimple2.loop())
    //do stuff in outer loop
    while (pimple2.correct())
         //do stufff in inner loop
Now add a dictionary in your system/fvSolution file like this:
PIMPLE2
    nCorrectors         x;
    nOuterCorrectors    y;
Hope this helps.
Jansois is offline   Reply With Quote
[isoAdvector] Issues with modification of IsoAdvector Code raunakbardia OpenFOAM Community Contributions 16 September 4, 2020 05:36
possibility to perform two simple.loop inside the same code palarcon OpenFOAM Programming & Development 5 August 28, 2018 09:48
Type mismatch: Assigning a scalar to a Field<Type> inside templated BC code karlli OpenFOAM Programming & Development 2 August 28, 2017 01:25
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 11:44
What kind of Cmmercial CFD code you feel well? Lans Main CFD Forum 13 October 27, 1998 10:20
