twoPhaseEulerFoam (gas-solid fluidized bed)
Old   November 13, 2021, 15:05
Question twoPhaseEulerFoam (gas-solid fluidized bed)
Hamed Hoorijani
Hamedhoorijani is on a distinguished road
Hello everyone.
I'm doing a simulation of a gas-solid fluidized bed using twoPhaseEulerFoam of OpenFOAM. I built my simulation case based on the fluidized bed tutorial of the OpenFOAM. Now I have a problem with the case that I don't have the exact values of the alphaMax and alphaMinFriction from the experiments, but I know based on the literature and particles size it should be somewhere between 0.58-0.62.
For the alphaMinFriction I don't know its relation with the characteristics of the particles but I know almost everyone considers a 0.5 value for this parameter. ( If anyone has a clue about the relation of its value with the characteristics of the particle I would like to know.)
For some reason, if I set the value of the alphaMax at 0.95 the pressure drop and the value of the minimum fluidization velocity obtained are right but if I set it to 0.6, I get an increasing trend for the pressure drop with increasing the inlet gas velocity.
I'll appreciate it if anyone could guide me on how to fix this problem. for your consideration, I attach my case to this post.
Thanks alot
Hamedhoorijani is offline   Reply With Quote
alphamax, kinetic theory, openfoam, simulation, twophaseeulerfoam
twoPhaseEulerFoam: sudden crash hcen OpenFOAM Running, Solving & CFD 18 September 29, 2020 03:04
twoPhaseEulerFoam validation OpenFOAM 4.1 jiejie OpenFOAM Running, Solving & CFD 4 April 20, 2019 03:06
twoPhaseEulerFoam fluidized bed wrong results FabianB OpenFOAM Running, Solving & CFD 0 June 14, 2017 03:48
Is twoPhaseEulerFoam applicable to 3D cases / delivering erroneous results? ThomasV OpenFOAM 0 November 11, 2013 08:10
twoPhaseEulerFoam freemankofi OpenFOAM 0 May 23, 2011 16:24
