OpenFOAM parallelization error - local length error
Old   April 27, 2021, 07:09
Default OpenFOAM parallelization error - local length error
Gowthaman Parivendhan
gowthaman is on a distinguished road
Hi All,
I'm having issues with foam-extend-4.0 when I run cases on the cluster. My solver compiles successfully and the case runs on a single processor. When I submit the job with multiple nodes, the cases usually runs but many a time also fail with an error stating, "rc_verbs_iface.c:64 send completion with error: local length error". Since it fails randomly, I assume it has to be an issue with either the way I compile foam-extend or with the openmpi. I tried looking up for this but I couldn't resolve this yet. Since my programming skills are limited, I would really appreciate if you have any suggestions that might fix this issue.
I have attached the bashrc and prefs.sh files that I've used to compile foam-extend in the cluster. P.S. I tried compiling with different options and since the jobs fail randomly, it is difficult to say if the compilation worked or not until the jobs fail eventually.
Thanks in advance for your time and help
gowthaman is offline   Reply With Quote
Old   November 23, 2021, 11:54
johanesp is on a distinguished road
I have the exact same problem! I am running parallel cases on a cluster at my univeristy, and this error comes up at seemingly rendom times. Sometimes the simulation runs, sometimes it doesn't. Let me know if you figure this one out!
johanesp is offline   Reply With Quote
cluster setup, compilation, foam-extend 4.0, parrallel run
[OpenFOAM] ParaView command in Foam-extend-4.1 mitu_94 ParaView 0 March 4, 2021 13:46
Pressure outlet boundary condition rolando OpenFOAM Running, Solving & CFD 62 September 18, 2017 06:45
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
