Calculation of the thrust produced by a propeller |
December 3, 2021, 06:53 |
hirota tomohiro
Rep Power: 4 |
Hello everyone.
Thank you very much for your help. I have been trying to reproduce the rotation of a propeller using the MRF method. First of all, I would like to thank you all for your advice, which helped me to successfully reproduce the rotation. At this point, I'm stuck because I don't know the process of calculating the thrust produced by the propeller. I know that foces and forcecoeffs can calculate the force and torque, but is it possible to calculate the thrust in OpenFOAM? Is it possible to calculate thrust in OpenFOAM? Or is it common to calculate it using filters in visualization software such as ParaView? I have attached a mesh of the rotation region in the analysis area. I would be grateful for any advice. Thank you very much. |
mrf, propeller, thrust |
Calculation of thrust and torque for propeller | aeksberde | OpenFOAM Post-Processing | 2 | October 28, 2019 05:23 |
Propeller thrust | Shrutirao | FLUENT | 1 | March 8, 2019 04:43 |
Force Calculation in OpenFOAM for Propeller case | bmaldi | OpenFOAM Running, Solving & CFD | 2 | May 2, 2018 04:33 |
calculation of thrust thrugh a pipe with CD nozzle | izhar | Main CFD Forum | 0 | February 28, 2009 09:22 |
Propeller thrust at diff. advance ratio (CFX 5.7) | Zoltan | CFX | 9 | April 27, 2005 08:23 |
