CFD quaestion about my sphere OpenFoam case
Old   December 16, 2021, 02:53
Default CFD quaestion about my sphere OpenFoam case
mohammad
mostanad is on a distinguished road
Hi every one,
I am trying to simulate the flow around a sphere at Re=1. To this end, I have generated a grid over the sphere using snappyHexMesh and a sphere stl file. The grid is something like below:
I know that for a sphere, in physics, only the relative velocity matters. So in my initial case, I just considered the flow over a sphere with free stream velocity equal to +0.015 corresponding to my Re number. You can see the following velocity field.
which the drag value is in about 3% relative to the literature, and the flow field look reasonable.
I another case, I just specified the velocity on the surface patch of the particle equal to U=-0.015 m/sec, as only the relative velocity matters. I should mention that I have remeshed the domain, and I am only giving a fixedValue velocity BC.
The drag value for this is again equal to my freestream case. However, although the sphere has a velocity to the right, the sphere wake region occurs in the front region of sphere.
So can anyone tell me what is happening with my relative velocity cases, when the drag force is completely matches?
Mohammad
mostanad is offline   Reply With Quote
Old   December 16, 2021, 06:00
mohammad
So from the CFD point of view, what is the difference between a free-stream case and moving boundary sphere?!
Any help in this regard is appreciated.
Old   December 19, 2021, 03:32
mohammad
Sorry guys. I know it might be hard to understand my problem. But it is only about keeping the sphere stationary and having freestream flow and moving the sphere in the stagnant flow.
What us MRF? Can it be used for this case?
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 11:58
Solvers in OpenFOAM for LES + heat transfer arun1994 Main CFD Forum 1 November 26, 2021 07:57
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 08:51
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 06:15
