Control valve type boundary condition, or mass flow restriction |
December 9, 2021, 15:57 |
Sebastian Zermeno
I am setting up a simulation for a piping system in which I need to simulate the flow through a valve. The valve won't be moving for the whole simulation so it must be a simple boundary condition. I've tried calculating the volume flow myself and setting the flow through this valve as some percentage of this volume flow but this approach tends to be very unstable. is there any special boundary condition that adjusts the volume flow as a function of an internal variable? say, something like newVolumeFlow=0.5*volumeFlow without having to do hand calculations I would appreciate any help if you have any ideas to approach this problem thank you zermenos Last edited by zermenos; December 13, 2021 at 03:33. |
Openfoam Turbulent Car Simulation | meganrw | OpenFOAM Running, Solving & CFD | 0 | July 5, 2021 15:50 |
twoPhaseEulerFoam confined plunging jet simulation failed | ves | OpenFOAM Running, Solving & CFD | 2 | June 17, 2020 05:08 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
