December 7, 2021, 07:25 |
multiphaseEulerFoam FOAM FATAL IO ERROR
qutadah
Rep Power: 4 |
Hi everyone, I am having the following error when running a two-phase flow in OpenFOAM.
The original case works perfectly and doesnt have any issues, I come across this issue when i change some values of alpha or U in the boundary conditions... * I am using collated filehandler and parallel processing using two nodes, 48 processors each. Code:
--> FOAM FATAL IO ERROR: Expected a ')' while reading binaryBlock, found on line 21 the word 'e▒L▒3' file: /rwthfs/rz/cluster/hpcwork/jg235250/SetupsMarkus/EE2F-MUSIG/06_3D_Pumpe_M1_v6_Qtot696_IGVF_5_SST_OF9_EE2F_MUSIG/0.288173000000247/U.water at line 21. From function Foam::Istream &Foam::Istream::readEnd(const char *) in file db/IOstreams/IOstreams/Istream.C at line 109. |
December 7, 2021, 13:25 |
qutadah
Rep Power: 4 |
so i dont know what caused this still, i was using nano editor to edit the binary boundary files... I just copied the original case again and used vi editor and it worked.... Even though i did the same and edited the binary files with nano and got this error .....
If someone knows if nano editor messes up the binary files somehow please let me kindly know, thanks |
December 8, 2021, 12:56 |
Similar problems
David
Rep Power: 6 |
I am experiencing almost similar issues, in my case I swapped out the cavitating bullet geometry with a 3D hydrofoil and I tried to carefully change the boundary conditions. The mesh was ok but when I ran the command "interPhaseChangeFoam" I got the error below
Please can anyone help! engr@engr-dave:~/foam/dave-4.0/run/cavitatingBullet$ of8 engr@engr-dave:~/foam/dave-4.0/run/cavitatingBullet$ interPhaseChangeFoam /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 8-1c9b5879390b Exec : interPhaseChangeFoam Date : Dec 09 2021 Time : 00:16:41 Host : "engr-dave" PID : 13384 I/O : uncollated Case : /home/engr/foam/dave-4.0/run/cavitatingBullet nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: No convergence criteria found PIMPLE: No corrector convergence criteria found Calculations will do 3 corrections PIMPLE: Operating solver in transient mode with 3 outer correctors Reading field p_rgh Reading field U Reading/calculating face flux field phi Creating phaseChangeTwoPhaseMixture Selecting phaseChange model SchnerrSauer Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon bounding k, min: 0 max: 0.06 average: 0.06 bounding epsilon, min: 0 max: 0.0495 average: 0.0495 RAS { model kEpsilon; turbulence on; printCoeffs on; Cmu 0.09; C1 1.44; C2 1.92; C3 0; sigmak 1; sigmaEps 1.3; } Reading g Reading hRef Calculating field g.h No finite volume options present GAMG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 7.40042e-07, global = 5.21498e-22, cumulative = 5.21498e-22 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #5 Foam::RASModels::kEpsilon<Foam::IncompressibleMome ntumTransportModel<Foam::transportModel> >::correctNut() at ??:? #6 ? in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/interPhaseChangeFoam" #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #8 ? in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/interPhaseChangeFoam" Floating point exception (core dumped) engr@engr-dave:~/foam/dave-4.0/run/cavitatingBullet$ |
December 8, 2021, 21:48 |
#4 | |
Ashutosh
Rep Power: 4 |
You can also try changing schemes. |
December 9, 2021, 02:46 |
David
Rep Power: 6 |
December 9, 2021, 07:12 |
Error message when calculating with interPhaseChangeFoam
#6 | |
David
Rep Power: 6 |
I also tried to calculate using the 2D version of the same hydrofoil and the calculation started running but after a while, it terminated with an error message as shown below. Please I need your help with this problem Courant Number mean: 1.31656e-06 max: 5.03315 Interface Courant Number mean: 3.78911e-07 max: 5.03315 deltaT = 1.85645e-46 Time = 3.31999e-06 PIMPLE: Iteration 1 smoothSolver: Solving for alpha.water, Initial residual = 7.9757e-08, Final residual = 2.59373e-12, No Iterations 1 Phase-1 volume fraction = 0.963473 Min(alpha.water) = -0.113975 Max(alpha.water) = 1.9541 MULES: Correcting alpha.water MULES: Correcting alpha.water Liquid phase volume fraction = 0.963473 Min(alpha.water) = -0.113975 Max(alpha.water) = 1.9541 smoothSolver: Solving for Ux, Initial residual = 0.784898, Final residual = 0.0776456, No Iterations 6 smoothSolver: Solving for Uy, Initial residual = 0.784338, Final residual = 0.0728061, No Iterations 8 GAMG: Solving for p_rgh, Initial residual = 2.50221e-33, Final residual = 2.50221e-33, No Iterations 0 PIMPLE: Iteration 2 smoothSolver: Solving for alpha.water, Initial residual = 1.83132e-08, Final residual = 1.94545e-12, No Iterations 1 Phase-1 volume fraction = 0.963473 Min(alpha.water) = -0.113974 Max(alpha.water) = 1.9541 MULES: Correcting alpha.water MULES: Correcting alpha.water Liquid phase volume fraction = 0.963473 Min(alpha.water) = -0.113974 Max(alpha.water) = 1.9541 smoothSolver: Solving for Ux, Initial residual = 0.673668, Final residual = 0.0639442, No Iterations 9 smoothSolver: Solving for Uy, Initial residual = 0.627473, Final residual = 0.0565589, No Iterations 5 GAMG: Solving for p_rgh, Initial residual = 2.08326e-32, Final residual = 2.08326e-32, No Iterations 0 PIMPLE: Iteration 3 smoothSolver: Solving for alpha.water, Initial residual = 2.30372e-08, Final residual = 3.42331e-12, No Iterations 1 Phase-1 volume fraction = 0.963473 Min(alpha.water) = -0.113974 Max(alpha.water) = 1.9541 MULES: Correcting alpha.water MULES: Correcting alpha.water Liquid phase volume fraction = 0.963473 Min(alpha.water) = -0.113974 Max(alpha.water) = 1.9541 smoothSolver: Solving for Ux, Initial residual = 0.575274, Final residual = 2.32922e-06, No Iterations 1000 smoothSolver: Solving for Uy, Initial residual = 0.649715, Final residual = 2.30958e-06, No Iterations 1000 GAMG: Solving for p_rgh, Initial residual = 6.85021e-34, Final residual = 6.85021e-34, No Iterations 0 smoothSolver: Solving for epsilon, Initial residual = 6.91275e-18, Final residual = 9.62875e-19, No Iterations 1 bounding epsilon, min: -1.24782e+114 max: 2.56052e+128 average: 6.87117e+124 smoothSolver: Solving for k, Initial residual = 0.938039, Final residual = 1.12015e-05, No Iterations 1000 bounding k, min: -3.96646e+78 max: 8.53537e+82 average: 3.25647e+80 ExecutionTime = 473.36 s ClockTime = 473 s Courant Number mean: 4.39296e-07 max: 18.162 Interface Courant Number mean: 6.7485e-08 max: 1.3656 deltaT = 5.11082e-47 Time = 3.31999e-06 PIMPLE: Iteration 1 smoothSolver: Solving for alpha.water, Initial residual = 1.24025e-08, Final residual = 3.75624e-14, No Iterations 1 Phase-1 volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 MULES: Correcting alpha.water MULES: Correcting alpha.water Liquid phase volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 smoothSolver: Solving for Ux, Initial residual = 0.873234, Final residual = 0.044149, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.956389, Final residual = 0.0385667, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 2.12784e-32, Final residual = 2.12784e-32, No Iterations 0 PIMPLE: Iteration 2 smoothSolver: Solving for alpha.water, Initial residual = 5.95103e-09, Final residual = 1.06362e-12, No Iterations 1 Phase-1 volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 MULES: Correcting alpha.water MULES: Correcting alpha.water Liquid phase volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 smoothSolver: Solving for Ux, Initial residual = 0.885566, Final residual = 0.0729296, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.951138, Final residual = 0.0617451, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 1.44958e-31, Final residual = 1.44958e-31, No Iterations 0 PIMPLE: Iteration 3 smoothSolver: Solving for alpha.water, Initial residual = 4.63717e-07, Final residual = 2.58962e-11, No Iterations 1 Phase-1 volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 MULES: Correcting alpha.water MULES: Correcting alpha.water Liquid phase volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 smoothSolver: Solving for Ux, Initial residual = 0.905716, Final residual = 9.8713e-07, No Iterations 210 smoothSolver: Solving for Uy, Initial residual = 0.942901, Final residual = 9.99183e-07, No Iterations 169 GAMG: Solving for p_rgh, Initial residual = 1.77193e-31, Final residual = 1.77193e-31, No Iterations 0 smoothSolver: Solving for epsilon, Initial residual = 9.18298e-13, Final residual = 1.07957e-18, No Iterations 1 bounding epsilon, min: -2.89875e+109 max: 1.91737e+128 average: 7.25083e+124 smoothSolver: Solving for k, Initial residual = 0.960219, Final residual = 0.000947622, No Iterations 1000 bounding k, min: -4.85718e+78 max: 2.00365e+87 average: 9.3082e+82 ExecutionTime = 473.82 s ClockTime = 473 s Courant Number mean: 1.11795e-05 max: 760.236 Interface Courant Number mean: 1.34447e-08 max: 0.326501 deltaT = 3.36133e-49 Time = 3.31999e-06 PIMPLE: Iteration 1 smoothSolver: Solving for alpha.water, Initial residual = 3.14423e-10, Final residual = 2.10051e-16, No Iterations 1 Phase-1 volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 MULES: Correcting alpha.water MULES: Correcting alpha.water Liquid phase volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 smoothSolver: Solving for Ux, Initial residual = 0.898913, Final residual = 0.0463407, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.965174, Final residual = 0.0949937, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 2.03761e-30, Final residual = 2.03761e-30, No Iterations 0 PIMPLE: Iteration 2 smoothSolver: Solving for alpha.water, Initial residual = 3.8785e-10, Final residual = 2.14871e-15, No Iterations 1 Phase-1 volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 MULES: Correcting alpha.water MULES: Correcting alpha.water Liquid phase volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 smoothSolver: Solving for Ux, Initial residual = 0.945497, Final residual = 0.0425314, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.890285, Final residual = 0.0789811, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 2.32038e-29, Final residual = 2.32038e-29, No Iterations 0 PIMPLE: Iteration 3 smoothSolver: Solving for alpha.water, Initial residual = 1.54941e-08, Final residual = 8.2065e-13, No Iterations 1 Phase-1 volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 MULES: Correcting alpha.water MULES: Correcting alpha.water Liquid phase volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 smoothSolver: Solving for Ux, Initial residual = 0.980694, Final residual = 9.85966e-07, No Iterations 621 smoothSolver: Solving for Uy, Initial residual = 0.845164, Final residual = 9.83645e-07, No Iterations 598 GAMG: Solving for p_rgh, Initial residual = 6.60654e-29, Final residual = 6.60654e-29, No Iterations 0 smoothSolver: Solving for epsilon, Initial residual = 1.13019e-14, Final residual = 2.9905e-16, No Iterations 1 bounding epsilon, min: -8.95102e+115 max: 1.29507e+128 average: 6.2465e+124 smoothSolver: Solving for k, Initial residual = 0.89142, Final residual = 0.0248855, No Iterations 1000 bounding k, min: -1.02608e+81 max: 1.19168e+87 average: 3.5906e+84 ExecutionTime = 474.5 s ClockTime = 474 s Courant Number mean: 2.93316e-05 max: 543.774 Interface Courant Number mean: 1.269e-06 max: 145.594 deltaT = 3.09075e-51 Time = 3.31999e-06 PIMPLE: Iteration 1 smoothSolver: Solving for alpha.water, Initial residual = 4.16811e-09, Final residual = 9.74614e-13, No Iterations 1 Phase-1 volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 MULES: Correcting alpha.water MULES: Correcting alpha.water Liquid phase volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 smoothSolver: Solving for Ux, Initial residual = 0.986337, Final residual = 0.0408722, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.99739, Final residual = 0.055142, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 6.89508e-26, Final residual = 6.89508e-26, No Iterations 0 PIMPLE: Iteration 2 smoothSolver: Solving for alpha.water, Initial residual = 2.20691e-07, Final residual = 3.93015e-12, No Iterations 1 Phase-1 volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 MULES: Correcting alpha.water MULES: Correcting alpha.water Liquid phase volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 smoothSolver: Solving for Ux, Initial residual = 0.984175, Final residual = 0.0316829, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.998156, Final residual = 0.0649702, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 1.65663e-25, Final residual = 1.65663e-25, No Iterations 0 PIMPLE: Iteration 3 smoothSolver: Solving for alpha.water, Initial residual = 0.000573257, Final residual = 1.26673e-09, No Iterations 1 Phase-1 volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 MULES: Correcting alpha.water MULES: Correcting alpha.water Liquid phase volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 smoothSolver: Solving for Ux, Initial residual = 0.989864, Final residual = 1.63168e-05, No Iterations 1000 smoothSolver: Solving for Uy, Initial residual = 0.992148, Final residual = 8.81591e-06, No Iterations 1000 GAMG: Solving for p_rgh, Initial residual = 1.41589e-24, Final residual = 1.41589e-24, No Iterations 0 smoothSolver: Solving for epsilon, Initial residual = 1.9448e-08, Final residual = 2.42767e-09, No Iterations 1 bounding epsilon, min: -4.72803e+115 max: 1.29219e+128 average: 6.24286e+124 smoothSolver: Solving for k, Initial residual = 0.90641, Final residual = 0.0565075, No Iterations 1000 bounding k, min: -1.87534e+83 max: 2.70993e+92 average: 6.16761e+88 ExecutionTime = 475.36 s ClockTime = 475 s Courant Number mean: 0.00342074 max: 57888.8 Interface Courant Number mean: 0.00157151 max: 56837.4 deltaT = 1.08757e-55 Time = 3.31999e-06 PIMPLE: Iteration 1 smoothSolver: Solving for alpha.water, Initial residual = 2.46886e-07, Final residual = 5.77144e-13, No Iterations 1 Phase-1 volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 MULES: Correcting alpha.water MULES: Correcting alpha.water Liquid phase volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 smoothSolver: Solving for Ux, Initial residual = 0.989243, Final residual = 0.0532337, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.97756, Final residual = 0.0346156, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 3.312e-24, Final residual = 3.312e-24, No Iterations 0 PIMPLE: Iteration 2 smoothSolver: Solving for alpha.water, Initial residual = 5.29372e-08, Final residual = 7.05084e-14, No Iterations 1 Phase-1 volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 MULES: Correcting alpha.water MULES: Correcting alpha.water Liquid phase volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 smoothSolver: Solving for Ux, Initial residual = 0.972908, Final residual = 0.0578711, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.953992, Final residual = 0.0306631, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 1.10713e-22, Final residual = 1.10713e-22, No Iterations 0 PIMPLE: Iteration 3 smoothSolver: Solving for alpha.water, Initial residual = 3.09189e-08, Final residual = 5.15276e-12, No Iterations 1 Phase-1 volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 MULES: Correcting alpha.water MULES: Correcting alpha.water Liquid phase volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 smoothSolver: Solving for Ux, Initial residual = 0.993079, Final residual = 1.65713e-05, No Iterations 1000 smoothSolver: Solving for Uy, Initial residual = 0.925153, Final residual = 0.000585797, No Iterations 1000 GAMG: Solving for p_rgh, Initial residual = 1.49259e-22, Final residual = 1.49259e-22, No Iterations 0 smoothSolver: Solving for epsilon, Initial residual = 6.01779e-07, Final residual = 2.68609e-13, No Iterations 1 bounding epsilon, min: -3.35361e+120 max: 9.43312e+131 average: 2.17325e+128 smoothSolver: Solving for k, Initial residual = 0.83036, Final residual = 0.0011249, No Iterations 1000 bounding k, min: -3.71259e+83 max: 2.37214e+102 average: 3.15691e+98 ExecutionTime = 476.21 s ClockTime = 476 s Courant Number mean: 4.45473e-05 max: 266.226 Interface Courant Number mean: 2.69846e-07 max: 4.90987 deltaT = 2.04258e-57 Time = 3.31999e-06 PIMPLE: Iteration 1 smoothSolver: Solving for alpha.water, Initial residual = 2.05394e-09, Final residual = 2.378e-16, No Iterations 1 Phase-1 volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 MULES: Correcting alpha.water MULES: Correcting alpha.water Liquid phase volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0624997, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0624997, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 5.95873e-21, Final residual = 5.95873e-21, No Iterations 0 PIMPLE: Iteration 2 smoothSolver: Solving for alpha.water, Initial residual = 3.14317e-09, Final residual = 4.02205e-13, No Iterations 1 Phase-1 volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 MULES: Correcting alpha.water MULES: Correcting alpha.water Liquid phase volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 smoothSolver: Solving for Ux, Initial residual = 0.98147, Final residual = 0.0315776, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.999539, Final residual = 0.031261, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 1.29708e-20, Final residual = 1.29708e-20, No Iterations 0 PIMPLE: Iteration 3 smoothSolver: Solving for alpha.water, Initial residual = 1.29734e-08, Final residual = 2.68178e-12, No Iterations 1 Phase-1 volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 MULES: Correcting alpha.water MULES: Correcting alpha.water Liquid phase volume fraction = 0.963473 Min(alpha.water) = -0.113971 Max(alpha.water) = 1.9541 smoothSolver: Solving for Ux, Initial residual = 0.919007, Final residual = 9.24707e-07, No Iterations 12 smoothSolver: Solving for Uy, Initial residual = 0.70392, Final residual = 6.86551e-07, No Iterations 11 GAMG: Solving for p_rgh, Initial residual = 2.05474e-19, Final residual = 2.05474e-19, No Iterations 0 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::multiply(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam::tmp<Foam:imensionedField<double, Foam::volMesh> > Foam:perator*<Foam::volMesh>(Foam::tmp<Foam:im ensionedField<double, Foam::volMesh> > const&, Foam:imensionedField<double, Foam::volMesh> const&) in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/interPhaseChangeFoam" #5 Foam::RASModels::kEpsilon<Foam::IncompressibleMome ntumTransportModel<Foam::transportModel> >::correct() at ??:? #6 ? in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/interPhaseChangeFoam" #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #8 ? in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/interPhaseChangeFoam" Floating point exception (core dumped) |
December 9, 2021, 20:03 |
Ashutosh
Rep Power: 4 |
There is probably issue with boundary condition. Can you upload your case folder.
December 9, 2021, 21:34 |
David
Rep Power: 6 |
I have uploaded the zero and system folders in zipped format, kindly find attached
December 9, 2021, 22:13 |
#9 |
Ashutosh
Rep Power: 4 |
I will check. I will let you know if I am able to made any progress.
December 10, 2021, 01:08 |
#10 |
David
Rep Power: 6 |
December 10, 2021, 09:53 |
3d hydrofoil case file
#11 |
David
Rep Power: 6 |
Night-hawk I removed the polymesh folder just like you suggested and the file size dropped significantly. I have uploaded the 3D case folder.
Secondly, as you can see from the screenshot attached, the 2D case is currently calculating thanks to your correction but so far I have not seen a single calculation folder been generated by OpenFOAM in my case folder. It seems abnormal. Please what can I do about this? |
December 10, 2021, 20:18 |
#12 |
Ashutosh
Rep Power: 4 |
Your write interval seems don't match with deltaT.
multiphasee |
[OpenFOAM] ParaView command in Foam-extend-4.1 | mitu_94 | ParaView | 0 | March 4, 2021 13:46 |
Mesquite - Adaptive mesh refinement / coarsening? | philippose | OpenFOAM Running, Solving & CFD | 94 | January 27, 2016 09:40 |
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x | Saxwax | OpenFOAM Installation | 25 | November 29, 2013 05:34 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 12:34 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
