PimpleFoam running surfaceNormalFixedValue BC |
December 12, 2021, 06:01 |
Nursultan
Rep Power: 5 |
Hello everyone!
I run the PimpleFoam case. It is an artery that has 1 inlet and 9 outlets. Actually, it is a blood flow laminar transient problem. I need to use surfaceNormalFixedValue boundary condition because it is more suitable. The problem is at the inlet velocity value is 0.25 m/s, however, at the outlets, there are very small values. Even if I change the inlet velocity the outlet values stay inadequately small and the same as previously. According to the mass conservation, the law velocity at the outlets should be near the inlet value. I appreciate it if somebody can help fix this problem. That problem in boundary conditions or in the mesh? The simulation setup is attached in the zip file. To run the case you can execute the PimpleCase.txt file. Also, residuals and velocity plots are attached. |
Running Case in Parallel | Typ | Main CFD Forum | 5 | May 11, 2020 03:43 |
Slow running of pimpleDyMFoam with respect to pimpleFoam. | gj11 | OpenFOAM Running, Solving & CFD | 2 | June 18, 2015 11:59 |
Segmentation fault when running in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 8, 2015 08:12 |
Fluent 14.0 file not running in parallel mode in cluster | tejakalva | FLUENT | 0 | February 4, 2015 07:02 |
Problem running IDDES with pimpleFoam | charlie | OpenFOAM Running, Solving & CFD | 7 | July 11, 2013 11:45 |
