How to access scalarField values correctly
Old   November 22, 2021, 13:22
Lightbulb How to access scalarField values correctly
ChenYe
chenye1717 is on a distinguished road
Dear all,
I am new to OpenFOAM and I have met a problem of accessing the scalarField element values in my code. Please help to take a look.
I used a 3D fluent mesh file generated by ICEM and concerted to OpenFOAM by 'Fluent3DMeshToFoam'. The simulation works well but I want to also output the surface element area at the inlet. So I tried to modify ./0/U using 'codedFixedValue'.
According to some online resources, I have done these:
const fvPatch& boundaryPatch = patch();
const fvBoundaryMesh& boundaryMesh = boundaryPatch.boundaryMesh();
const fvMesh& mesh = boundaryMesh.mesh();
label patchID = mesh.boundaryMesh().findPatchID("INLET_R");
const surfaceScalarField& magSf = mesh.magSf();
const scalarField& magSf0 = magSf.boundaryField()[patchID];
As you may see, I have found the patchID of the particular inlet I am looking at and the value of patchID is correct. My question is how can I output the values in either magSf or magSf0 one by one?
I have tried to output the sum of both magSf and magSf0 by 'gSum(magSf.boundaryField()[patchID])' and 'gSum(magSf0)'. The values are both correct.
I tried to use:
forAll(magSf.boundaryField()[patchID],ii)
Info << "ii "<<ii<<" Area "<<magSf.boundaryField()[patchID][ii]<<endl;
But it never outputs. Could you guys help to find out the reason?
Thanks, and best regards.
chenye1717 is offline   Reply With Quote
Old   December 13, 2021, 13:55
Smile
ChenYe
Hi all,
This issue has been fixed. The problem is caused by the inconsistent mesh information between fluent mesh and the initial simulation file of ./constant/polyMesh/boundary.
Thanks!
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 06:55
How to calculate T+gradT where T is volScalarField and gradT is scalarField ??? Zhiheng Wang OpenFOAM Programming & Development 4 May 28, 2016 13:51
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 22:38
max node values exceed max element values in contour plot jason_t FLUENT 0 August 19, 2009 11:32
exact face values RubenG Main CFD Forum 0 June 22, 2009 11:09
