Floating Point Error Using AMI
Old   December 13, 2021, 17:44
Default Floating Point Error Using AMI
Will
Dr.Mann is on a distinguished road
I'm new to using the AMI feature on OpenFoam and I am having trouble running my mesh. I can create the mesh fine using snappyHexMesh but when I try to run the case using simpleFoam, the case fails on the first iteration and gives me a floating point exception. I've also tried converting the case over to pimpleFoam and the case still fails.
I have attached my case files.
Any Help is much appreciated!
Dr.Mann is offline   Reply With Quote
Old   December 15, 2021, 16:37
Will
I figured out my issue, the weights on my AMI surface were at 0 so I modified my SHM so that they weren't. The sim started running after that.
Here is the thread that helped me resolve the issue.
Periodic cyclic AMI + MRF crashing on pressure
ami, dynamicmesh error, openfoam
Error running AMI propeller simulation luitzor OpenFOAM Running, Solving & CFD 0 April 19, 2021 13:48
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 14:07
[snappyHexMesh] snappyHexMesh and cyclic boundaries Ruli OpenFOAM Meshing & Mesh Conversion 2 December 9, 2013 06:51
pimpleDyMFoam constantly giving floating point exception and solution divergence fedvasu OpenFOAM Running, Solving & CFD 0 November 28, 2013 00:53
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 09:53
