January 10, 2022, 16:21 |
writeInterval not working
Gabriel
Rep Power: 4 |
Hi, i modified pitzdaily from pimpleFoam tutorial, to adjust it to my case, which is flow into a box with spherical fruits, when i run pimpleFoam it doesn´t write data every writeInterval no matter what value i use.
case: https://www.dropbox.com/s/a692lrsi23...foam3.zip?dl=0 log.pimplefoam file: https://www.dropbox.com/s/i4aw2g7kls...efoam.txt?dl=0 controldict: Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application pimpleFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 0.3; deltaT 0.0001; writeControl adjustableRunTime; writeInterval 0.01;//0.01; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable yes; adjustTimeStep yes; maxCo 1; functions { #includeFunc patchAverage(patch=inlet, fields=(p U)) } // ************************************************************************* // |
Porous media coefficients and working fluid | Dronzer | FLUENT | 1 | June 30, 2020 22:23 |
writeInterval not working | cmoreno98 | OpenFOAM Running, Solving & CFD | 3 | March 2, 2020 03:55 |
findCell() in parallel: not working if location is outside the domain | TobiWol | OpenFOAM | 0 | January 10, 2018 14:33 |
Processor 0 not working | vishwesh | OpenFOAM Running, Solving & CFD | 0 | November 17, 2017 03:35 |
DPM parallel is not working but serial is working | johnwinter | FLUENT | 1 | March 27, 2012 02:01 |
