OpenQBMM moments reconstructPoint Distribution |
December 23, 2022, 06:00 |
AmolG
Rep Power: 9 |
I am trying to use the utility "reconstructPointDistribution" of OpenQBMM version 9 with OpenFOAM-v2206.
I have used a tutorial case of Tyalor Dispersion solved with pbeTransportFoam. When I use generateMoment utility it works fine. I want to use reconstructPointDistribution utility on result or say on the initial "0" time, I have kept the pointDistributionDict in system directory. When I run the command reconstructPointDistribution I get following error. [amol.ganjare@mercury TaylorDispersion]$ reconstructPointDistribution /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2206 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _76d719d1e6-20220624 OPENFOAM=2206 version=v2206 Arch : "LSB;label=32;scalar=64" Exec : reconstructPointDistribution Date : Dec 23 2022 Time : 16:23:14 Host : mercury PID : 32539 I/O : uncollated Case : /nas1/amol.ganjare/OF_2206/OpenFOAM-v2206/modules/OpenQBMM/tutorials/pbeTransportFoam/TaylorDispersion nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM Warning : From static Foam::IOstreamOption::compressionType Foam::IOstreamOption::compressionEnum(const Foam::word&, Foam::IOstreamOption::compressionType) in file db/IOstreams/IOstreams/IOstreamOption.C at line 115 Unknown compression specifier 'uncompressed', using compression off Create mesh for time = 42 Reading pointDistributionDict Reading quadratureProperties.populationBalance --> FOAM Warning : From virtual void Foam:robes::findElements(const Foam::fvMesh&) in file probes/probes.C at line 230 Did not find location (0 0.5 0.5) in any cell. Skipping location. Reading moment.0.populationBalanceMean Reading moment.1.populationBalanceMean Reading moment.2.populationBalanceMean Reading moment.3.populationBalanceMean Reading moment.4.populationBalanceMean Selecting extendedMomentInversion: lognormal Selecting univariateMomentInversion: Gauss --> FOAM FATAL ERROR: (openfoam-2206) The zero-order moment is negative. Moment set: 5{-1e+300} From void Foam::univariateMomentSet::checkRealizability(bool ) in file univariateMomentSet/univariateMomentSet.C at line 208. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::error::simpleExit(int, bool) at ??:? #2 Foam::error::exiting(int, bool) at ??:? #3 Foam::univariateMomentSet::checkRealizability(bool ) at ??:? #4 ? at ??:? #5 __libc_start_main in /lib64/libc.so.6 #6 ? at ??:? Aborted (core dumped) I get similar error on other case and data as well. Error is same for all the cases with different initial moments. --> FOAM FATAL ERROR: (openfoam-2206) The zero-order moment is negative. Moment set: 5{-1e+300} Is there anything that I am missing out? |
moment, openfoam-v2206, openqbmm, reconstructpoints |
Problem with own Lagrangian particle size distribution model | Patrick_18 | OpenFOAM Programming & Development | 0 | March 9, 2022 01:16 |
OpenQBMM error when initialized moments are set to zero | kuria | OpenFOAM Programming & Development | 0 | May 7, 2021 04:41 |
size distribution models in OpenFOAM 4.x | minzhang | OpenFOAM Running, Solving & CFD | 1 | March 30, 2018 18:10 |
Need Help-Calculation of ship trimming moments | Anam | FLUENT | 0 | May 20, 2013 07:40 |
maintaining a logarithmic velocity distribution | Morten Andersen | CFX | 1 | January 8, 2007 11:37 |
