January 17, 2022, 00:10 |
Odd results with view factor + solar load
Bushra Rasheed
Rep Power: 5 |
Hi!
I am simulating a case with view factor radiation modeling turned on along with solar load model. The qr primary results I am getting seem reasonable but the total qr contours I am getting are very distorted and have very unreasonable values. I am attaching screenshots for reference. The bottom face is opaque reflective with (0.03 0.07) absorptivity / emisssivity Please help! Thanks! |
January 17, 2022, 05:30 |
Yann
Rep Power: 26 |
Just my 2 cents, but I think the "distortion" you see on the qr cells is related to the face agglomeration performed before computing the view factors. Depending on which faces are agglomerated together, and where the grouped faces are located relatively to the shadow of your object, you might get those weird values. I hope this helps somehow. Yann |
January 17, 2022, 06:06 |
#3 | |
Bushra Rasheed
Rep Power: 5 |
I checked face agglomeration . Actually the distortion started to come when I divided the panel boundaries into front panel surface and rear panel surface ( My previous qr values were very low i.e. 170 W/m2 for solar radiations) . I included only rear surface and ground in view factor boundaries and then this error started to come. |
January 18, 2022, 04:53 |
#4 | |
Bushra Rasheed
Rep Power: 5 |
radiation heat flux, solar load model, view factor model |
how to view the complete results | shokry | FLOW-3D | 5 | February 3, 2009 13:56 |
load multiples results en CFX-post | Lana | CFX | 1 | September 16, 2008 11:20 |
CFDesign v9.0 won't load results | Joe Shifrin | Autodesk Simulation CFD | 5 | July 31, 2008 11:49 |
view results file... | Gopal | CFX | 1 | October 9, 2006 01:30 |
CFX load Results file | furkan | CFX | 2 | August 24, 2006 07:18 |
