January 17, 2022, 03:42 |
Error in porousSimpleFoam
Teh Tiong Wei
Rep Power: 4 |
I am trying to implement porousSimpleFoam in my case and there is an error which I do not understand and I could not find much about it either. Here is the error: HTML Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _7bdb509494-20201222 OPENFOAM=2012 Arch : "LSB;label=32;scalar=64" Exec : porousSimpleFoam Date : Jan 17 2022 Time : 09:01:05 Host : MSI PID : 1646 I/O : uncollated Case : /home/wei/OpenFOAM_files/work_ICVT/yarn1 nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: no convergence criteria found. Calculations will run for 1000 steps. Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon RAS { RASModel kEpsilon; turbulence on; printCoeffs on; Cmu 0.09; C1 1.44; C2 1.92; C3 0; sigmak 1; sigmaEps 1.3; } No MRF models present No finite volume options present Creating porosity model list from porosityProperties Porosity region porosity1: selecting model: DarcyForchheimer --> FOAM FATAL IO ERROR: (openfoam-2012) Entry 'cellZone' has 6 excess tokens in stream 7(insideZone1 d ( 5e+07 5e+07 5e+07 )) file: /home/wei/OpenFOAM_files/work_ICVT/yarn1/constant/porosityProperties.porosity1 at line 22. FOAM exiting HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object porosityProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // porosity1 { type DarcyForchheimer; cellZone insideZone1 d (5e7 5e7 5e7); f (0 0 0); coordinateSystem { origin (0 0 0); e1 (1 0 0); e2 (0 1 0); e3 (0 0 1); } } porosity2 { type DarcyForchheimer; cellZone insideZone2 d (5e7 5e7 5e7); f (0 0 0); coordinateSystem { origin (0 0 0); e1 (1 0 0); e2 (0 1 0); e3 (0 0 1); } } porosity3 { type DarcyForchheimer; cellZone insideZone3 d (5e7 5e7 5e7); f (0 0 0); coordinateSystem { origin (0 0 0); e1 (1 0 0); e2 (0 1 0); e3 (0 0 1); } } // ************************************************************************* // Thanks in advance! |
January 17, 2022, 03:49 |
Teh Tiong Wei
Rep Power: 4 |
Okay I finally found out it was due to the missing semi colon....
Problem solved :-) |
fatal io error, porous cell zone, poroussimplefoam |
porousSimpleFoam | aban | OpenFOAM | 10 | July 20, 2022 03:01 |
porousSimpleFoam ended prematurely and may have crashed. exit code 3 | Vishsel | OpenFOAM Running, Solving & CFD | 0 | May 9, 2019 06:50 |
How do I analyse the odd results (with porousSimpleFoam) ? | deepbandivadekar | OpenFOAM Running, Solving & CFD | 3 | January 17, 2018 05:15 |
[snappyHexMesh] Is it possible to set flow to laminar with porousSimpleFoam solver? | Caio Martins | OpenFOAM Meshing & Mesh Conversion | 3 | May 17, 2016 14:12 |
porousSimpleFoam - crash | Sebaj | OpenFOAM | 2 | January 4, 2012 16:16 |
