very high pressure
Old   January 14, 2022, 16:48
Default very high pressure
Gabriel
daylen is on a distinguished road
Hi, iīm simulating flow through a box with vents containing 6 spheres, what i donīt understand is that the results from the simulations shows very high pressure drop between inlet and outlet (42000 kinematic pressure at inlet and -10000 at outlet). is the simulation realistic?
simpleFoam case:
https://www.dropbox.com/s/pntr90nqtc...foam2.zip?dl=0
daylen is offline   Reply With Quote
Old   January 15, 2022, 09:33
Tobermory will become famous soon enough
Yes, it makes sense. Look at the velocity and you'll see that you have a velocity of around 150m/s through each vent. So the (kinematic) dynamic pressure is Pd=0.5 * U^2 = 11,250. If we assume a loss coefficient of Cd=2 for the simple orifice, then that gives a dP of 22,500 per baffle, i.e. 44,500 between inlet and outlet. That matches the pressure you quoted.
The real question is: why do you have a hurricance passing through your vents? The answer: check your boundary condition. You are forcing in air at 6.68m/s at the inlet, and then this constructs do at the vents ... to 150m/s.
So, have a rethink about your BCs. The good news is that the code appears to be working nicely.
Tobermory is offline   Reply With Quote
Old   January 19, 2022, 18:49
Gabriel
ok thanks for your answer
High negative pressure with interPhaseChangeFoam legione OpenFOAM Running, Solving & CFD 7 July 5, 2015 10:28
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 11:26
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
