The alphaeqn in 2 phase incomprossible flow (driftFluxFoam)
Old   April 8, 2020, 05:46
Default The alphaeqn in 2 phase incomprossible flow (driftFluxFoam)
Elol
Elol is on a distinguished road
Hello Foamers,
Right now , I am trying to develope my own incombressible multiphase slover starting from icoFoam solver. So, I bring the first step which I will add the alphaEqn form driftFLuxFoam to the solver (I use driftFluxFoam Solver as a refrence). However there is some questions regarding the solution method of the alphaEqn.
the alphaEqn.H file solve this eqn ddt(alpha,t)+div(alpha, U) = 0 as follow:
word alphaScheme("div(phi,alpha)");
word alpharScheme("div(phirb,alpha)");
if (MULESCorr)
fvScalarMatrix alpha1Eqn
fv::EulerDdtScheme<scalar>(mesh).fvmDdt(alpha1)
+ fv::gaussConvectionScheme<scalar>
mesh,
phi,
upwind<scalar>(mesh, phi)
).fvmDiv(phi, alpha1)
solve(alpha1Eqn);
Info<< "Phase-1 volume fraction = "
<< alpha1.weightedAverage(mesh.Vsc()).value()
<< " Min(" << alpha1.name() << ") = " << min(alpha1).value()
<< " Max(" << alpha1.name() << ") = " << max(alpha1).value()
<< endl;
tmp<surfaceScalarField> talphaPhiUD(alpha1Eqn.flux());
alphaPhi = talphaPhiUD();
if (alphaApplyPrevCorr && talphaPhiCorr0.valid())
Info<< "Applying the previous iteration correction flux" << endl;
MULES::correct
geometricOneField(),
alpha1,
alphaPhi,
talphaPhiCorr0.ref(),
UniformField<scalar>(mixture.alphaMax()),
zeroField()
alphaPhi += talphaPhiCorr0();
// Cache the upwind-flux
talphaPhiCorr0 = talphaPhiUD;
for (int aCorr=0; aCorr<nAlphaCorr; aCorr++)
tmp<surfaceScalarField> talphaPhiUn
fvc::flux
phi,
alpha1,
alphaScheme
+ fvc::flux
phir,
alpha1,
alpharScheme
if (MULESCorr)
tmp<surfaceScalarField> talphaPhiCorr(talphaPhiUn() - alphaPhi);
volScalarField alpha10("alpha10", alpha1);
MULES::correct
alpha1,
talphaPhiUn(),
talphaPhiCorr.ref(),
zeroField()
// Under-relax the correction for all but the 1st corrector
if (aCorr == 0)
alphaPhi += talphaPhiCorr();
else
alpha1 = 0.5*alpha1 + 0.5*alpha10;
alphaPhi += 0.5*talphaPhiCorr();
else
alphaPhi = talphaPhiUn;
MULES::explicitSolve
alpha1,
phi,
alphaPhi,
zeroField()
if (alphaApplyPrevCorr && MULESCorr)
talphaPhiCorr0 = alphaPhi - talphaPhiCorr0;
alpha2 = 1.0 - alpha1;
<< endl;
What I understand till this moment is that it starts to solve the equation using low order scheme to generate talphaPhiUD() in this section
mesh,
phi,
solve(alpha1Eqn);
<< endl;
then and *if condition* is applied to perform MULES
MULES::correct
alpha1,
alphaPhi,
zeroField()
alphaApplyPrevCorr is an inlet from the user and here is my question :
1. why they apply MULES correction to the low order fluxes ?
2. what this condition (talphaPhiCorr0.valid()) mean ?
Thank you guys in advance.
Elol is offline   Reply With Quote
Old   February 20, 2022, 12:46
MNM
SHUBHAM9595 is on a distinguished road
Hi Elol,
I'm also facing bit difficulty in understanding specific meaning of these terms clearly. Can you share if you found an answer or some resource where it is mentioned clearly.
SHUBHAM9595 is offline   Reply With Quote
Old   March 16, 2022, 12:40
Elol
Hi MNM,
Sorry for the late answer, I don't know if you find the answer or not. After some research, I really advise you to take a look on the PhD thesis of Santiago Marquez Damian. It is entitled as " An Extended Mixture Model for the Simultaneous Treatment of Short and Long Scale Interfaces". He explained in chapter 2 the whole idea of weighting factors and how it is implemnted in openFoam.
Enjoy reading it. It is really valuable work.
Best regards
Elol
Discrete Phase Model, outlet mass flow rate does not fit edu_aero FLUENT 29 February 3, 2020 08:38
CFX siphon two phase flow - boundary conditions bolus13 CFX 18 August 25, 2016 18:39
Two phase flow problem. andyraq Fluent Multiphase 4 August 21, 2016 21:57
gas-liquid 2 phase flow in microchannels using VoF LyngHoo FLUENT 1 November 13, 2012 19:01
how 2 freeze 1 phase flow field & start lagrangian KK CFX 5 February 14, 2008 16:48
