LPT of multiple clouds
Old   April 30, 2022, 13:26
Default LPT of multiple clouds
ffran is on a distinguished road
I have a relatively simple case to run: I have a simple periodic channel flow and I want to seed it with three clouds of Lagrangian particles (same material, different sizes) with one way coupling. However, I have seen that most of the solvers can only track one single kinematic cloud. Do you have any suggestions on how to go on, apart from running three different simulations?
Regards,
Francesco
ffran is offline   Reply With Quote
Old   May 2, 2022, 10:06
Julio Pieri
JulioPieri is on a distinguished road
Hi Francesco, I had a similar problem recently and I managed to word around using swak4Foam. I was able to create multiple clouds by adding multiple 'injectionModels' to the kinematicCloudProperties file in constant folder.
Here is an example:
injectionModels
        D1mm
            type            patchInjection;
            massTotal       0;
            parcelBasisType fixed;
            patch       outlet;
            nParticle       1;
            SOI             5.7;
            duration        0.1;
            U0              ( 0 0 -0.01 );
            parcelsPerSecond  400;
            sizeDistribution
                type        fixedValue;
                fixedValueDistribution
                    value   0.001;
            flowRateProfile constant 0.1;
        D2mm
            massTotal       0;
            patch       outlet;
            nParticle       1;
            SOI             5.6;
            duration        0.1;
            U0              ( 0 0 -0.01 );
            sizeDistribution
                type        fixedValue;
                    value   0.002;
        D3mm
            massTotal       0;
            patch       outlet;
            nParticle       1;
            SOI             5.5;
            duration        0.1;
            U0              ( 0 0 -0.01 );
            sizeDistribution
                type        fixedValue;
                    value   0.003;
I haven't tried this in native OF solvers, but I believe it might work as well.
JulioPieri is offline   Reply With Quote
Old   May 2, 2022, 10:43
Here is an example:
injectionModels
        D1mm
            massTotal       0;
            patch       outlet;
            nParticle       1;
            SOI             5.7;
            duration        0.1;
            U0              ( 0 0 -0.01 );
            sizeDistribution
                type        fixedValue;
                    value   0.001;
        D2mm
            massTotal       0;
            patch       outlet;
            nParticle       1;
            SOI             5.6;
            duration        0.1;
            U0              ( 0 0 -0.01 );
            sizeDistribution
                type        fixedValue;
                    value   0.002;
        D3mm
            massTotal       0;
            patch       outlet;
            nParticle       1;
            SOI             5.5;
            duration        0.1;
            U0              ( 0 0 -0.01 );
            sizeDistribution
                type        fixedValue;
                    value   0.003;
Wow, sounds like a good idea, I will try!
How did you distinguish the different clouds in postprocessing? They have the same particle ID, right? Did you make the solver print the injectionModel in the outputs?
Francesco
Old   May 2, 2022, 10:49
Julio Pieri
For my purpose, thresholding the diameter was enough. And yes, they had the same ID
Old   May 2, 2022, 12:54
I understand. Thank you very much for your help!
Francesco
lpt, multiple, one way, openfoam
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
How to include multiple lagrangian particle clouds? lf.lopez18 OpenFOAM Pre-Processing 1 September 3, 2020 04:39
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 04:17
[OpenFOAM.org] Install openFOAM 3.0.1 in Ubuntu 16.04 LTS from Deb packs Pier84 OpenFOAM Installation 4 June 18, 2016 16:22
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
