Problems with adding gravity field in icoFoam
Old   May 3, 2022, 03:10
Default Problems with adding gravity field in icoFoam
ZY GONG
Gzy52597 is on a distinguished road
Hi Foamers,
I try to add gravity field in icoFoam to simulate natural cycle.
I added gravity term in UEqn and external heat source in TEqn.Then and run my code in the Square Cavity Flow.When I got the result,I found the mesh velocity for the upper and lower boundary regions is very large,but the mesh velocity of the inner area looks normal.The same is true for calculating only one step.
I can't understand where my problem is and how should I fix it. I'm guessing there might be a problem with the pressure correction.I will put my code and data at the end.For the convenience of calculation, I changed the unit of g Q rho.And The version I am using is OF9.
Thanks very much.
GZY
#include "fvCFD.H"
#include "pisoControl.H"
int main(int argc, char *argv[])
    #include "setRootCaseLists.H"
    #include "createTime.H"
    #include "createMesh.H"
    pisoControl piso(mesh);
    #include "createFields.H"
    #include "initContinuityErrs.H"
         int ixx;
	double   ttt[50000];
	double   r[50000];
    Info<< "\nStarting time loop\n" << endl;
    while (runTime.loop())
	ixx=0;
	forAll(T, cellI)
	 ttt[ixx]=T[cellI];
         r[ixx]=11112.0-1.375*ttt[ixx];
         rho[cellI]=r[ixx];
         ixx++;
        Info<< "Time = " << runTime.timeName() << nl << endl;
        #include "CourantNo.H"
        // Momentum predictor
        fvVectorMatrix UEqn
           fvm::ddt(rho,U)
          +rho*fvm::div(phi, U)
          -rho*fvm::laplacian(nu, U)
          -rho*g
        if (piso.momentumPredictor())
            solve(UEqn == -fvc::grad(p));
        // --- PISO loop
        while (piso.correct())
            volScalarField rAU(1.0/UEqn.A());
            volVectorField HbyA(constrainHbyA(rAU*UEqn.H(), U, p));
            surfaceScalarField phiHbyA
                "phiHbyA",
                fvc::flux(HbyA)
              + fvc::interpolate(rAU)*fvc::ddtCorr(U, phi)
            adjustPhi(phiHbyA, U, p);
            // Update the pressure BCs to ensure flux consistency
            constrainPressure(p, U, phiHbyA, rAU);
            // Non-orthogonal pressure corrector loop
            while (piso.correctNonOrthogonal())
                // Pressure corrector
                fvScalarMatrix pEqn
                    fvm::laplacian(rAU, p) == fvc::div(phiHbyA)
                pEqn.setReference(pRefCell, pRefValue);
                pEqn.solve();
                if (piso.finalNonOrthogonalIter())
                    phi = phiHbyA - pEqn.flux();
            #include "continuityErrs.H"
            U = HbyA - rAU*fvc::grad(p);
            U.correctBoundaryConditions();
        fvScalarMatrix TEqn
            fvm::ddt(T)
            + fvm::div(phi, T)
            - fvm::laplacian(DT, T)
            - Q
        TEqn.solve();
        runTime.write();
        Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
            << "  ClockTime = " << runTime.elapsedClockTime() << " s"
            << nl << endl;
    Info<< "End\n" << endl;
    return 0;
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  9
     \\/     M anipulation  |
FoamFile
    format      ascii;
    class       volVectorField;
    location    "0.005";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   nonuniform List<vector>
400
(-0.000476508 -0.0115647 0)
(-0.000784292 -0.0141864 0)
(-0.000701793 -0.0145204 0)
(-0.000441974 -0.0144738 0)
(-0.000303848 -0.01444 0)
(-0.000210945 -0.014424 0)
(-0.000155563 -0.0144202 0)
(-0.000103963 -0.0144227 0)
(-6.11593e-05 -0.0144235 0)
(-2.02327e-05 -0.0144246 0)
(1.83156e-05 -0.0144272 0)
(5.45208e-05 -0.0144308 0)
(9.28129e-05 -0.0144343 0)
(0.000138576 -0.0144355 0)
(0.000195968 -0.0144346 0)
(0.000279105 -0.0144434 0)
(0.000425148 -0.0144788 0)
(0.000690445 -0.0145067 0)
(0.000775659 -0.0141518 0)
(0.000464067 -0.0115457 0)
(-0.000279845 0.00058314 0)
(-0.000574868 6.00372e-05 0)
(-0.000647177 -0.000375036 0)
(-0.000525152 -0.000333578 0)
(-0.000396586 -0.000237777 0)
(-0.000283292 -0.000197922 0)
(-0.000200873 -0.000172021 0)
(-0.000135336 -0.000162975 0)
(-8.11926e-05 -0.000157578 0)
(-2.98633e-05 -0.000155306 0)
(2.02394e-05 -0.000156322 0)
(7.29662e-05 -0.000160124 0)
(0.000136072 -0.000168787 0)
(0.000212373 -0.000185309 0)
(0.000300992 -0.000211916 0)
(0.000407737 -0.000257972 0)
(0.000539512 -0.000338687 0)
(0.000669973 -0.000374779 0)
(0.000571927 7.23082e-05 0)
(0.000267958 0.000585769 0)
(-0.000146075 0.00146615 0)
(-0.000302954 0.00091659 0)
(-0.000400162 0.000154317 0)
(-0.000367859 0.000105362 0)
(-0.000309357 0.000191787 0)
(-0.000246301 0.000248938 0)
(-0.000177506 0.000285114 0)
(-0.0001239 0.000304454 0)
(-7.58013e-05 0.000316463 0)
(-2.88559e-05 0.000322221 0)
(1.74775e-05 0.000323569 0)
(6.47452e-05 0.000321497 0)
(0.000120121 0.000311088 0)
(0.0001874 0.000286184 0)
(0.000259934 0.00024447 0)
(0.000329647 0.000181473 0)
(0.000392799 0.000100537 0)
(0.000416622 0.000136878 0)
(0.000306533 0.000893589 0)
(0.000123069 0.00148334 0)
(-0.000103847 0.00129893 0)
(-0.00018492 0.000686034 0)
(-0.000256443 -0.000221688 0)
(-0.000256455 -0.000325991 0)
(-0.000228186 -0.000287855 0)
(-0.000191544 -0.000227248 0)
(-0.000147711 -0.00019162 0)
(-0.000105681 -0.00016832 0)
(-6.46852e-05 -0.000152233 0)
(-2.33659e-05 -0.000143875 0)
(1.96885e-05 -0.000140995 0)
(6.18209e-05 -0.000140798 0)
(0.000104104 -0.000146745 0)
(0.000151296 -0.000167606 0)
(0.000200794 -0.000209243 0)
(0.000242342 -0.000271219 0)
(0.000265512 -0.000329492 0)
(0.000257181 -0.000226404 0)
(0.000174954 0.000673636 0)
(6.56123e-05 0.00130062 0)
(-6.06883e-05 0.00135316 0)
(-0.000125181 0.000754353 0)
(-0.000161296 -0.000204864 0)
(-0.000175726 -0.000350977 0)
(-0.000173099 -0.000326226 0)
(-0.000144624 -0.00028089 0)
(-0.00011779 -0.000247851 0)
(-8.43999e-05 -0.000222369 0)
(-5.13396e-05 -0.000203586 0)
(-1.76159e-05 -0.000192964 0)
(2.05519e-05 -0.000190593 0)
(5.89788e-05 -0.000194886 0)
(9.31998e-05 -0.000205482 0)
(0.000124114 -0.00022569 0)
(0.000150879 -0.000261492 0)
(0.000171882 -0.000310083 0)
(0.000179313 -0.000346719 0)
(0.000167005 -0.000194923 0)
(0.000112448 0.000763859 0)
(4.92095e-05 0.00136683 0)
(-2.70273e-05 0.00138085 0)
(-7.09724e-05 0.000796374 0)
(-0.000107227 -0.000168792 0)
(-0.000117999 -0.000360173 0)
(-0.000120237 -0.000335366 0)
(-0.000107655 -0.0003045 0)
(-8.83872e-05 -0.000274656 0)
(-6.12995e-05 -0.000251233 0)
(-3.52628e-05 -0.000234299 0)
(-1.03709e-05 -0.000223323 0)
(1.77641e-05 -0.000220531 0)
(4.69153e-05 -0.000228229 0)
(7.31836e-05 -0.000245872 0)
(9.44838e-05 -0.000271115 0)
(0.000110886 -0.000306219 0)
(0.000119251 -0.000344077 0)
(0.000120852 -0.000359249 0)
(0.000115228 -0.000177217 0)
(7.97267e-05 0.000803964 0)
(3.83064e-05 0.0014104 0)
(-1.6703e-05 0.00141444 0)
(-3.61677e-05 0.00083495 0)
(-6.53342e-05 -0.000147352 0)
(-8.21881e-05 -0.000344961 0)
(-7.94882e-05 -0.000341308 0)
(-7.83826e-05 -0.00031741 0)
(-6.37168e-05 -0.00029073 0)
(-4.39258e-05 -0.000271722 0)
(-2.34131e-05 -0.0002606 0)
(-3.845e-06 -0.000253703 0)
(1.56437e-05 -0.000251971 0)
(3.36205e-05 -0.000258951 0)
(5.01968e-05 -0.000276594 0)
(6.296e-05 -0.000302396 0)
(7.23847e-05 -0.00033215 0)
(8.09131e-05 -0.000361436 0)
(8.60585e-05 -0.000358308 0)
(7.65403e-05 -0.000161845 0)
(4.99976e-05 0.000828385 0)
(1.86187e-05 0.00144306 0)
(-5.37094e-06 0.00143108 0)
(-2.21076e-05 0.000880941 0)
(-3.65244e-05 -0.0001379 0)
(-5.17891e-05 -0.000329686 0)
(-5.47333e-05 -0.00034505 0)
(-5.15419e-05 -0.000323492 0)
(-4.18926e-05 -0.00029992 0)
(-3.10514e-05 -0.000282762 0)
(-1.72268e-05 -0.00027413 0)
(-1.73994e-06 -0.000271222 0)
(1.2514e-05 -0.000273632 0)
(2.22753e-05 -0.000281577 0)
(2.96213e-05 -0.000295393 0)
(3.8121e-05 -0.000315964 0)
(4.63096e-05 -0.000336938 0)
(5.51392e-05 -0.00035452 0)
(6.02754e-05 -0.000342835 0)
(4.68219e-05 -0.000143088 0)
(2.73084e-05 0.000863295 0)
(3.03072e-06 0.00146559 0)
(1.12998e-06 0.00144226 0)
(-1.49048e-05 0.000897853 0)
(-2.69431e-05 -0.000119724 0)
(-2.91617e-05 -0.000327525 0)
(-3.53389e-05 -0.000342124 0)
(-2.77164e-05 -0.00032369 0)
(-2.21796e-05 -0.000305454 0)
(-1.80188e-05 -0.00028991 0)
(-1.18553e-05 -0.000280293 0)
(-3.34473e-06 -0.000277348 0)
(5.28575e-06 -0.000281954 0)
(1.18427e-05 -0.000292742 0)
(1.56928e-05 -0.000305616 0)
(2.06077e-05 -0.000320302 0)
(2.82915e-05 -0.000336329 0)
(3.70589e-05 -0.000348993 0)
(3.73128e-05 -0.000337925 0)
(2.91021e-05 -0.000137081 0)
(1.7157e-05 0.000880993 0)
(3.30246e-06 0.00147645 0)
(-1.56015e-06 0.00146079 0)
(-1.21387e-05 0.000882067 0)
(-1.46624e-05 -0.000117336 0)
(-1.40117e-05 -0.000335749 0)
(-1.29428e-05 -0.000342116 0)
(-9.33577e-06 -0.000326634 0)
(-7.30431e-06 -0.000312759 0)
(-5.77275e-06 -0.000300222 0)
(-4.64805e-06 -0.000290631 0)
(-3.39861e-06 -0.000286618 0)
(-2.88267e-06 -0.000289264 0)
(-1.40338e-06 -0.000298825 0)
(1.94434e-06 -0.000311816 0)
(6.60057e-06 -0.000324948 0)
(1.20809e-05 -0.000340242 0)
(1.55854e-05 -0.000356148 0)
(1.20084e-05 -0.000351515 0)
(1.31528e-05 -0.000145057 0)
(7.55417e-06 0.000864676 0)
(4.69622e-06 0.00148753 0)
(4.65326e-07 0.00146405 0)
(-4.86963e-06 0.000879666 0)
(4.4215e-06 -0.000127734 0)
(6.2362e-06 -0.000337023 0)
(1.17325e-05 -0.000344929 0)
(7.17696e-06 -0.000331373 0)
(5.04003e-06 -0.000316971 0)
(4.22683e-06 -0.000305334 0)
(1.76543e-06 -0.000295904 0)
(-1.97513e-06 -0.000291222 0)
(-6.92348e-06 -0.000291289 0)
(-1.07265e-05 -0.000296302 0)
(-1.05476e-05 -0.00030599 0)
(-8.62608e-06 -0.00031926 0)
(-8.44592e-06 -0.00033682 0)
(-1.21709e-05 -0.00035665 0)
(-1.17752e-05 -0.000351366 0)
(-9.95408e-06 -0.000139387 0)
(-6.91761e-06 0.00086166 0)
(-4.45231e-06 0.0014964 0)
(3.00096e-06 0.00146342 0)
(5.83287e-06 0.000886522 0)
(1.97425e-05 -0.0001312 0)
(2.89706e-05 -0.000333301 0)
(3.06631e-05 -0.000349255 0)
(2.41587e-05 -0.000335492 0)
(1.95427e-05 -0.000316445 0)
(1.54124e-05 -0.000301385 0)
(9.48059e-06 -0.000291166 0)
(1.21881e-06 -0.000285598 0)
(-7.96511e-06 -0.00028456 0)
(-1.6122e-05 -0.000287413 0)
(-2.11313e-05 -0.000295223 0)
(-2.50372e-05 -0.000310045 0)
(-3.0846e-05 -0.000330894 0)
(-3.69171e-05 -0.000351411 0)
(-3.09075e-05 -0.000338626 0)
(-2.96076e-05 -0.000134597 0)
(-1.58574e-05 0.000882293 0)
(-8.68051e-06 0.00148029 0)
(6.11444e-06 0.00146733 0)
(1.74452e-05 0.000861518 0)
(3.58317e-05 -0.000145923 0)
(4.83584e-05 -0.00034781 0)
(4.74971e-05 -0.00036128 0)
(4.55242e-05 -0.000341454 0)
(3.99551e-05 -0.000318099 0)
(2.96226e-05 -0.000297494 0)
(1.75686e-05 -0.000284228 0)
(4.63374e-06 -0.000276861 0)
(-8.74037e-06 -0.000275175 0)
(-2.14071e-05 -0.000278382 0)
(-3.32968e-05 -0.000287723 0)
(-4.51039e-05 -0.00030618 0)
(-5.53495e-05 -0.00033121 0)
(-5.78604e-05 -0.00035268 0)
(-5.51394e-05 -0.000341056 0)
(-4.17093e-05 -0.000149888 0)
(-2.50979e-05 0.000873629 0)
(-8.17557e-06 0.00146295 0)
(1.63191e-05 0.00145682 0)
(3.76641e-05 0.000816578 0)
(6.42587e-05 -0.000175604 0)
(7.37901e-05 -0.000370354 0)
(7.49747e-05 -0.000368946 0)
(7.28761e-05 -0.000337561 0)
(6.43102e-05 -0.000308994 0)
(4.94009e-05 -0.000286287 0)
(3.01309e-05 -0.000270199 0)
(1.02742e-05 -0.000260533 0)
(-9.48786e-06 -0.00025776 0)
(-2.86872e-05 -0.00026188 0)
(-4.90471e-05 -0.000273767 0)
(-6.93317e-05 -0.000294926 0)
(-8.28835e-05 -0.000322104 0)
(-8.47195e-05 -0.000346659 0)
(-8.82926e-05 -0.000350875 0)
(-6.80694e-05 -0.000156493 0)
(-4.18766e-05 0.000830494 0)
(-1.67365e-05 0.00145478 0)
(2.74598e-05 0.00143012 0)
(6.74051e-05 0.00078216 0)
(0.000106065 -0.000201189 0)
(0.000115184 -0.000375339 0)
(0.000118243 -0.000353124 0)
(0.000111012 -0.00031365 0)
(9.20368e-05 -0.000280461 0)
(6.85353e-05 -0.000258283 0)
(4.33395e-05 -0.000242893 0)
(1.70742e-05 -0.000233873 0)
(-1.00894e-05 -0.000232419 0)
(-3.7431e-05 -0.000239524 0)
(-6.6461e-05 -0.000255126 0)
(-9.42483e-05 -0.000278235 0)
(-0.000112618 -0.000307016 0)
(-0.000124585 -0.000339418 0)
(-0.000125142 -0.000360898 0)
(-0.000114887 -0.000171221 0)
(-6.54621e-05 0.000792436 0)
(-2.17338e-05 0.00141799 0)
(3.6731e-05 0.00139133 0)
(0.000106338 0.000742242 0)
(0.000164733 -0.000216152 0)
(0.000181967 -0.000360473 0)
(0.000174601 -0.000323063 0)
(0.000151071 -0.000276932 0)
(0.000120484 -0.000242087 0)
(8.7086e-05 -0.000219654 0)
(5.45574e-05 -0.000205837 0)
(2.075e-05 -0.000199047 0)
(-1.5141e-05 -0.000200027 0)
(-5.14106e-05 -0.000210086 0)
(-8.78752e-05 -0.000228477 0)
(-0.000122028 -0.00025331 0)
(-0.000149598 -0.000286626 0)
(-0.00017654 -0.000332725 0)
(-0.000180209 -0.000360032 0)
(-0.000168915 -0.000217211 0)
(-0.000110239 0.000753172 0)
(-3.17183e-05 0.00136639 0)
(6.07837e-05 0.00132863 0)
(0.000178459 0.000666719 0)
(0.000261387 -0.000230396 0)
(0.00026809 -0.000333102 0)
(0.000239646 -0.000280786 0)
(0.000197503 -0.000227572 0)
(0.000150117 -0.000191273 0)
(0.000104903 -0.000168191 0)
(6.39635e-05 -0.000154842 0)
(2.2886e-05 -0.000148427 0)
(-2.11305e-05 -0.000148561 0)
(-6.58981e-05 -0.000156504 0)
(-0.000109801 -0.000172362 0)
(-0.0001532 -0.000196627 0)
(-0.000197548 -0.000235648 0)
(-0.000235855 -0.000294126 0)
(-0.000269448 -0.000332287 0)
(-0.000257508 -0.000239968 0)
(-0.000174341 0.000672084 0)
(-6.59362e-05 0.00130697 0)
(0.000129858 0.00151113 0)
(0.000317835 0.000901535 0)
(0.000422243 0.000145241 0)
(0.000389877 0.000102005 0)
(0.000317646 0.000176802 0)
(0.000246027 0.00023391 0)
(0.000180653 0.000270772 0)
(0.000123631 0.00029454 0)
(7.43384e-05 0.000308284 0)
(2.70326e-05 0.000314659 0)
(-2.32206e-05 0.000315856 0)
(-7.52278e-05 0.00031197 0)
(-0.000128112 0.000301163 0)
(-0.000186102 0.000278804 0)
(-0.000252539 0.000237348 0)
(-0.000310695 0.000178495 0)
(-0.000384351 0.000100987 0)
(-0.000419006 0.000156826 0)
(-0.000301551 0.000911537 0)
(-0.000119368 0.00148901 0)
(0.000276081 0.000602357 0)
(0.000580548 8.68364e-05 0)
(0.000673144 -0.000368828 0)
(0.000532516 -0.000341173 0)
(0.0003958 -0.000261237 0)
(0.000288954 -0.000211701 0)
(0.000206308 -0.000182384 0)
(0.000139103 -0.000164107 0)
(8.20563e-05 -0.00015369 0)
(2.95404e-05 -0.000148889 0)
(-2.36009e-05 -0.000147626 0)
(-7.90156e-05 -0.000149339 0)
(-0.00013961 -0.000155894 0)
(-0.00021159 -0.000172872 0)
(-0.000293944 -0.000207094 0)
(-0.000397102 -0.000251231 0)
(-0.000524323 -0.000339575 0)
(-0.000654217 -0.000357801 0)
(-0.000568395 8.83562e-05 0)
(-0.000257792 0.00059742 0)
(0.000468668 -0.0115389 0)
(0.000792462 -0.014146 0)
(0.000711709 -0.0145149 0)
(0.000449865 -0.014498 0)
(0.000301484 -0.0144619 0)
(0.000212398 -0.0144417 0)
(0.000149998 -0.0144296 0)
(0.000100535 -0.0144206 0)
(5.86655e-05 -0.0144149 0)
(1.99577e-05 -0.0144127 0)
(-1.85699e-05 -0.014412 0)
(-5.73086e-05 -0.0144113 0)
(-9.84487e-05 -0.0144123 0)
(-0.000147885 -0.0144192 0)
(-0.000205072 -0.0144354 0)
(-0.000302038 -0.0144533 0)
(-0.000447744 -0.0144797 0)
(-0.000711567 -0.014507 0)
(-0.000787918 -0.0141431 0)
(-0.000457033 -0.0115368 0)
boundaryField
    Wall
        type            noSlip;
    fixedWalls
        type            noSlip;
    frontAndBack
        type            empty;
Gzy52597 is offline   Reply With Quote
chtMultiRegion not solving for velocity field obiscolly50 OpenFOAM Running, Solving & CFD 22 November 9, 2018 14:40
[swak4Foam] Need to use gravity field for defining the expression in swakFunction Esmaeelef OpenFOAM Community Contributions 5 May 1, 2017 18:01
Adding Temperature field to IcoFoam yapalparvi OpenFOAM Programming & Development 14 November 19, 2015 05:57
Having problems getting the mean vorticity field from mean velocity field Martin1 Fluent UDF and Scheme Programming 1 June 18, 2015 09:20
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
