High pressure air tank discharge simulation
Old   September 13, 2022, 07:14
Default High pressure air tank discharge simulation
Twisampati Roy Chowdury
Twisampati07 is on a distinguished road
Hello, I am new to OpenFOAM and I am trying to create a 3D pressure tank discharge simulation in OpenFOAM. The tank has a dimension of dia =10.16 cm, height =1m pressurised to 150 psi at 20 c. A small orifice is at the upper face of the tank of 1 mm radius which is further connected in a 1*1*1 m^3 fluid domain which is initially at 1 atm and 20c. I want to see how long it takes for the tank to empty until pressure of all the region comes to equilibrium. I tried creating the geometry in gmsh and meshed it using gmsh then I took shocktube tutorial of OpenFOAM and I just changed the geometry, meshing and patching parameters for my requirement and other settings as well to suit the simulation. But it looks like it is not working. Please help...
Please have a look on my simulation folder...
https://drive.google.com/drive/folde...Vx?usp=sharing
Twisampati07 is offline   Reply With Quote
gmsh, openfoam 10, patching, shocktube, tank drain
High negative pressure in incompressible flow simulation user_HH OpenFOAM Programming & Development 0 February 4, 2021 14:40
ANSYS Fluent Sloshing in baffled tank simulation Fisya CFD Freelancers 2 August 27, 2019 17:55
Simulation of ball-valve opening w.r.t to varying inlet pressure wasim_03 Main CFD Forum 1 January 6, 2018 12:40
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 13:04
high pressure on tank Martin_Sz CFX 2 January 21, 2015 05:50
