What is the best aproach for my geometry: SRF, MRF or AMI?
Old   May 29, 2022, 13:35
Question What is the best aproach for my geometry: SRF, MRF or AMI?
Anuar Giménez
anuargimenez is on a distinguished road
Hi all, I am trying to run a stationary compressible simulation of a polymer flow through a single screw extruder in OpenFoam 7, as the one shown below:
Here you can see the geometry that I am meshing. I am using Ansys for that.
As you can see, in contrast to typical rotor-stator problems, here the rotor (screw) is in contact with the stator (barrel).
I wonder what would be the best method to perform the simulation: SRF, MRF or Rotating Mesh.
- MRF aproach: due to the contact between rotor and stator, i have no stationary zone perpendicular to the axis of rotation (not so at the bottom). I thought if maybe a one cell thin mesh between the screw and the stator would work for me.
- SRF aproach: I think this is the best option for my geometry. However, as far as I know, OpenFoam does not have SRF solvers for compressible simulations. I am currently using rhoSimpleFoam which incorporates MRF. I found a compressible SRF solver in the OpenFoam extend version called "steadyCompressibleSRFFoam", however it is implemented for OpenFoam 4 and works with compressibility of gasses (it uses 1/RT), while i am working with density in liquids.
- Dynamic Mesh aproach: This is the last option that I have in mind. However, I don't know if a stationary solver or the contact between rotor and stator could be a problem.
In case I use MRF with a thin one cell layer, could I define the cellZone directly in Ansys Mesh?
It is worth converting the incompressible solver simpleSRFFoam to compressible, so I could use SRF? In that case, could you give me any references?
I would be very gratefull if you could give me some advice.
Thanks,
Anuar
anuargimenez is offline   Reply With Quote
ami, mrf, openfoam, srf, turbomachinery
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 04:53
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
Virtual/Real geometry. Jack Keays FLUENT 9 June 15, 2000 23:39
