Where is gSum implemented
Like Tree4Likes
  • 4 Post By leonardo13
Old   September 19, 2007, 12:35
Default Hi Foamers, sorry because thi
cosimo bianchini
cosimobianchini is on a distinguished road
Send a message via Skype™ to cosimobianchini
Hi Foamers,
sorry because this might be a trivial question.
I would like to have a look at the piece of code where gSum is implemented but I was not able to find it. Where is this function implemented?
I need to understand if in such case:
gSum(volScalarField.boundaryField());
processor boundaries are included in the sum or not.
Thanks in advance,
Cosimo
Cosimo Bianchini
Ergon Research s.r.l.
Via Panciatichi, 92
50127 Florence - ITALY
Tel: +39 055 0763716
Mob: +39 320 9460153
e-mail: cosimo.bianchini@ergonresearch.it
URL: www.ergonresearch.it
cosimobianchini is offline   Reply With Quote
Old   April 29, 2021, 13:07
Default gSum is built in a template
Leonardo Jesus Miranda MIyazaki
leonardo13 is on a distinguished road
gSum is implemented in FieldFieldFunctions.C as a template function.
First the G_UNARY_FUNCTION is defined:
#define G_UNARY_FUNCTION(ReturnType, gFunc, func, rFunc) \
template<template<class> class Field, class Type> \
ReturnType gFunc(const FieldField<Field, Type>& f) \
ReturnType res = func(f); \
reduce(res, rFunc##Op<ReturnType>()); \
return res; \
Then, gSum is defined as
G_UNARY_FUNCTION(Type, gSum, sum, sum)
Replacing the function imputs in the template the result is
Type gFunc(const FieldField<Field, Type>& f) {
Type res = sum(f);
reduce(res, sumOp<Type>());
return res;
Remember that reduce is a function to integrate operations from all the processors (parallel run). So, when using gSum, we are really using "reduce" backstage.
I know this thread is old, but hope some find help!
tonnykz, KillerBee, vsb and 1 others like this.
leonardo13 is offline   Reply With Quote
Old   June 7, 2022, 14:27
sadsid is on a distinguished road
Can we apply gSum on a list of scalars or vectors?
I tried the following code:
forAll(mesh.C(),i)
m_[Pstream::myProcNo()][i] = gSum((m[i].internalField()*mesh.V())());
But it gives error. If I use gSum((m.internalField()*mesh.V())()); without "[i]" then it does not give error but allocate a single value to the whole list of "m".
What I want to achieve: The summation should be performed on a per-element basis. That is the ith element of the array "m" are summed into the ith element of the resulting array (here m_).
return res; \
Type res = sum(f);
return res;
sadsid is offline   Reply With Quote
GammaContactAngle not implemented coastal593 OpenFOAM Running, Solving & CFD 5 November 9, 2010 05:21
Convective Schemes how are they implemented nicasch OpenFOAM Running, Solving & CFD 1 November 4, 2010 08:47
Understanding implemented PISO stephan OpenFOAM Running, Solving & CFD 0 January 28, 2006 11:11
Is it implemented the QUICK scheme in the CFX? Viana CFX 2 January 23, 2006 05:08
Has the adpativemesh feature be implemented in FOAM Luckyluke (Luckyluke) OpenFOAM Running, Solving & CFD 5 January 11, 2005 07:21
