MPPICFoam failed lookup of turbulenceProperties |
June 30, 2022, 03:24 |
Charl Maré
Dear All,
I doing a test case where I simulate particles travelling along a narrow square duct with a porous baffle (cyclic boundary conditions) located roughly half way between the inlet and outlet using the MPPICFoam solver. (Note I am using OpenFOAM v2112). I have sorted out allot of issues but now I am stuck on the following error/problem when I am run the solver: "failed lookup of turbulenceProperties (objectRegistry region0) available objects of type turbulenceModel: (turbulenceProperties.air)" I have looked at other CFD-online posts but they unfortunately were not of much help in the end. Just a note: The simulation runs when I remove the porous baffle and cyclic boundary conditions and change the faceType (for the cellZone and faceZone setup) in snappyHexMesh from baffle to internal. I have attached my OpenFOAM case files using to two different archive formats for your convenience. I would truly appreciate your input on the matter. Regards, Charl |
cyclic boundary condition, lagrangian partices, mppicfoam, openfoam, porous baffle |
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel | U.Golling | OpenFOAM Running, Solving & CFD | 52 | September 23, 2023 03:35 |
Long output in terminal. | ssa_cfd | OpenFOAM Running, Solving & CFD | 1 | March 18, 2019 05:25 |
DPMFoam - Serious Error --particle-laden flow in simple geometric config | benz25 | OpenFOAM Running, Solving & CFD | 27 | December 19, 2017 20:47 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
