For Runnig Multiple Iterations in a Single Time Step in chtMultiRegionFoam |
March 9, 2022, 00:22 |
Abhishek Dey
Rep Power: 4 |
I am relatively new in openFoam and currently I am using chtMultiRegionFoam Solver to solve a transient case. I want to run the solver for 20 times (i.e. for 20 iterations) in a single time step and also I want to give convergence criteria in each time step. Can anyone tell me how can I do this? |
March 9, 2022, 07:14 |
saidc
Rep Power: 6 |
Hi Abhishek,
If I understood you correctly, the PIMPLE algorithm does this. With residual control you can give convergence criteria. The algorithm is in fvSolution (i.e. tutorials/heatTransfer/buoyantPimpleFoam/hotRoom/system/fvSolution) dictionary. Lets say, you have, Code:
PIMPLE { nNonOrthogonalCorrectors 0; nCorrectors 1; nOuterCorrectors 50; residualControl { U { tolerance 1e-5; relTol 0; } p { tolerance 5e-4; relTol 0; } } } Usefull links: https://openfoamwiki.net/index.php/O...hm_in_OpenFOAM https://www.simscale.com/forum/t/cfd...lgorithm/81418 Kind regards, Said. |
November 9, 2022, 03:20 |
#3 | |
JuanMi
Rep Power: 8 |
"(PIMPLE | PISO)" { nOuterCorrectors 500; } Code:
PIMPLE { outerCorrectorResidualControl { U { tolerance 1e-5; relTol 0; } e { tolerance 5e-4; relTol 0; } } } |
chtmutiregionfoam, openfoam |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" | bigphil | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 686 | December 22, 2022 09:10 |
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 05:49 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
