Defining pre-existing Fracture as function of time and Position
Old   August 13, 2022, 18:35
Default Defining pre-existing Fracture as function of time and Position
Axel Dorian
Axello is on a distinguished road
Dear Foamers,
Using the basics model of Solid mechanics or Solids4Foam on FE4.0/4.1 for Solid Tutorials, on fractures, the pre-exisiting crack is predefined :
in the fvSolution file, we have :
crackLimitingBoxes
1(
(0 -1e-5 0)(0.06 1e-5 1) // -1e-5 ----- 1e5
and in the case file 0/U (D) for displacement, the crack is defined as :
crack
type solidCohesive;
relaxationFactor 0.01;
contact no;
penaltyScale 1;
frictionCoeff 0.1;
explicitSeparationDistance no;
value uniform ( 0 0 0 );
This assumes the crack height and width are fixed.
1. Please, how can I do to set the crack height/width as a function of time and position?
We have that G = - dΩ/ds , where :
Ω is the strain energy only affected by the change in fracture surface area: dΩ = (dΩ/ds)dΩ
G is the surface Energy release
s : crack surface area
in the file .....\src\solidModels\arbitraryCrack\solidCohesive \solidCohesiveFvPatchVectorField.C, the formula :
if ( ((currentGI_[i]/GIc[i]) + (currentGII_[i]/GIIc[i])) >= 1 )
//Pout << "GIc[i] is " << GIc[i] << ", curG is " << currentG << endl;
if (!cracked_[i])
Pout << "Face " << i << " is fully cracked" << endl;
cracked_[i] = true;
gives the condition criteria for propagation.
In the syntax below
if (dict.found("oldGI"))
oldGI_ = scalarField("oldGI", dict, p.size());
a declaration and definition of the variable oldGI ?
Or
In FE4.1/tut/solidMechanics/elasticAcpSolidFoam/crackingBiMatDcbDugdale/0 is it proper to define oldGI as follow:
crack
type solidCohesive;
contact no;
penaltyScale 1;
frictionCoeff 0.1;
oldGI 220; for instance
2. Regarding the Surface Energy release, how can one record or extract the data file of Energy release variation w.r.t. crack surface area, to time, and Temperature as well in thermal stress is included?
Thank you.
Axello is offline   Reply With Quote
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 21:00
Defining pre-existing Fracture as function of time and Position Axello OpenFOAM CC Toolkits for Fluid-Structure Interaction 12 February 14, 2023 11:14
should Courant number always be kept below 1? wc34071209 OpenFOAM Running, Solving & CFD 16 March 9, 2014 19:31
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
