Problem BC for a forced outlet flow, sucction
Old   August 29, 2022, 11:11
Default Problem BC for a forced outlet flow, sucction
gabriel rodrigues
Lucc is on a distinguished road
Hello, I'm currently trying to simulate turbulent flux of air (model k -epsilon) in a room.
This room has two inlets of air (similar to an air conditioner) where there's air flowing inside the room and underneath air being sucked from the environment, just like a real split model.
My problem is how to set the BC of this outlet that sucks air continously from the environment. Currently I'm using for U and P:
For U:
outlet
        type                flowRateOutletVelocity;
        volumetricFlowRate  0.2;
        value               uniform (0 0 0);
For p:
outlet:
        type            zeroGradient;
I'm starting from the principle that the BC for a sucction area is supoused to be equal as an inlet of air blowing into the envioronment. What i'm missing??
Thanks in advance!!
Lucc is offline   Reply With Quote
unable to run dynamic mesh(6dof) and wave UDF shedo Fluent UDF and Scheme Programming 0 July 1, 2022 17:22
Outlet BC: fixed outlet volumetric flow rate with reversed flow juanf OpenFOAM Pre-Processing 0 July 29, 2021 06:17
Stability Problem with sonicFoam for Nozzle Flow Julian K. OpenFOAM 3 July 11, 2016 08:14
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 02:10
Disturbed flow field at outlet boundary (Multiphase flow through pipe) Michiel CFX 17 April 21, 2010 10:14
