Problem BC for a forced outlet flow, sucction |
August 29, 2022, 11:11 |
gabriel rodrigues
Rep Power: 4 |
Hello, I'm currently trying to simulate turbulent flux of air (model k -epsilon) in a room.
This room has two inlets of air (similar to an air conditioner) where there's air flowing inside the room and underneath air being sucked from the environment, just like a real split model. My problem is how to set the BC of this outlet that sucks air continously from the environment. Currently I'm using for U and P: Code:
For U: outlet { type flowRateOutletVelocity; volumetricFlowRate 0.2; value uniform (0 0 0); } For p: outlet: { type zeroGradient; } Thanks in advance!! |
unable to run dynamic mesh(6dof) and wave UDF | shedo | Fluent UDF and Scheme Programming | 0 | July 1, 2022 17:22 |
Outlet BC: fixed outlet volumetric flow rate with reversed flow | juanf | OpenFOAM Pre-Processing | 0 | July 29, 2021 06:17 |
Stability Problem with sonicFoam for Nozzle Flow | Julian K. | OpenFOAM | 3 | July 11, 2016 08:14 |
Compressible flow, no data at the outlet | mireis | FLUENT | 6 | September 3, 2015 02:10 |
Disturbed flow field at outlet boundary (Multiphase flow through pipe) | Michiel | CFX | 17 | April 21, 2010 10:14 |
