prescribe an input boundary condition for the velocity |
October 13, 2022, 16:30 |
Alice Costa
Hello guys....
I started using OpenFoam recently and I still don't have much experience, so I would like your help regarding a model I'm simulating. It is an ventilation analysis in full-scale 2D street canyon, and I need to prescribe an input boundary condition for the velocity according to a profile described in a .csv file. I don't know if the error is in the input data, or in the way the code is written in the zero directory. I would like you to help me on how to proceed with this error. I'm using OpenFoam's BlueCFD-core 2017 terminal WhatsApp Image 2022-10-13 at 10.19.32 (4).jpeg ----------------------------------------------------------------------------------// --> FOAM FATAL IO ERROR: keyword file is undefined in dictionary "F:/3-SIMULACOES_MESTRADO/VALIDATION/VAL_YANG2/0/U.boundaryField.inlet.profileCoeffs" file: F:/3-SIMULACOES_MESTRADO/VALIDATION/VAL_YANG2/0/U.boundaryField.inlet.profileCoeffs from line 33 to line 38. From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const in file db/dictionary/dictionary.C at line 566. FOAM exiting -----------------------------------------------------------------------------------// ----------------------------------------------------------------------------------// U ----------------------------------------------------------------------------------// dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type fixedProfile; profile csvFile; profileCoeffs { nHeaderLine 0; refColumn 0; componentColumns 3(1 2 3); separator ";"; mergeSeparators 0; fileName "0/UProfile.csv"; } direction (0 0 1); origin 0; value nonuniform List<scalar> } outlet { type zeroGradient; } frontandback { type empty; } top { type symmetryPlane; } body { type fixedValue; value uniform (0 0 0); } ground { type fixedValue; value uniform (0 0 0); } } -------------------------------------------------/// UProfile.csv ------------------------------------------------/// 0.12106;1.115;0;0 0.12709;1.125;0;0 0.13497;1.14;0;0 0.14378;1.155;0;0 0.15213;1.1899;0;0 0.1577;1.1999;0;0 0.16466;1.2149;0;0 0.17161;1.2398;0;0 0.17625;1.2647;0;0 0.18367;1.2847;0;0 0.19341;1.3097;0;0 0.20176;1.3197;0;0 0.20686;1.3396;0;0 0.21429;1.3745;0;0 0.22078;1.3994;0;0 0.22866;1.4194;0;0 0.23887;1.4444;0;0 0.24675;1.4693;0;0 0.25557;1.5042;0;0 0.26716;1.5391;0;0 0.27783;1.579;0;0 0.28247;1.6089;0;0 0.28989;1.6388;0;0 0.29731;1.6538;0;0 0.30705;1.6887;0;0 0.31679;1.7385;0;0 0.32514;1.7635;0;0 0.33302;1.7934;0;0 0.34184;1.8332;0;0 0.35019;1.8632;0;0 0.35436;1.8881;0;0 0.35853;1.903;0;0 0.36596;1.913;0;0 0.37199;1.9678;0;0 0.37987;1.9878;0;0 0.38544;2.0276;0;0 0.39332;2.0525;0;0 0.40074;2.1023;0;0 0.40863;2.1223;0;0 0.41558;2.1572;0;0 0.42161;2.192;0;0 0.42811;2.2219;0;0 0.43646;2.2668;0;0 0.44249;2.3066;0;0 0.45037;2.3465;0;0 0.45918;2.3863;0;0 0.46753;2.4312;0;0 0.47495;2.476;0;0 0.48237;2.5258;0;0 0.49026;2.5607;0;0 0.49814;2.6204;0;0 0.50788;2.6653;0;0 0.51391;2.7051;0;0 0.52087;2.745;0;0 0.5269;2.7947;0;0 0.5334;2.8296;0;0 0.53942;2.8545;0;0 0.54592;2.8894;0;0 0.55241;2.9541;0;0 0.5603;30039;0;0 0.56865;3.0686;0;0 0.57885;3.1234;0;0 0.58395;3.1633;0;0 0.58952;3.218;0;0 0.59647;3.2529;0;0 0.6025;3.3027;0;0 0.60807;3.3475;0;0 0.61364;3.3973;0;0 0.61874;3.4421;0;0 0.6257;3.4769;0;0 0.63358;3.5417;0;0 0.63961;3.5914;0;0 0.64471;3.6313;0;0 0.65074;3.696;0;0 0.65584;3.7507;0;0 0.66234;3.7955;0;0 0.66929;3.8453;0;0 0.67625;3.8852;0;0 0.68089;3.9399;0;0 0.68599;3.9748;0;0 0.69109;4.0295;0;0 0.69666;4.0843;0;0 0.70362;4.1639;0;0 0.70965;4.2037;0;0 0.71382;4.2585;0;0 0.71985;4.3033;0;0 0.72449;4.358;0;0 0.72866;4.4.078;0;0 0.73562;4.4626;0;0 0.74304;4.5273;0;0 0.74768;4.577;0;0 0.75417;4.6418;0;0 0.75742;4.6915;0;0 0.76391;4.7512;0;0 0.76763;4.7911;0;0 0.77226;4.8458;0;0 0.77737;4.9055;0;0 0.78432;4.9851;0;0 0.78942;5.0498;0;0 0.79128;5.0747;0;0 0.79592;5.1394;0;0 0.80334;5.1942;0;0 0.80751;5.2589;0;0 0.81262;5.3335;0;0 0.81725;5.3833;0;0 0.82468;5.4579;0;0 0.82839;5.5127;0;0 0.8321;5.5624;0;0 0.83627;5.6122;0;0 0.83998;5.647;0;0 0.84369;5.6918;0;0 0.8474;5.7465;0;0 0.85297;5.8162;0;0 0.85853;5.8759;0;0 0.86503;5.9556;0;0 0.8692;6.0202;0;0 0.87338;6.1048;0;0 0.87987;6.1745;0;0 0.88544;6.2541;0;0 0.89239;6.3138;0;0 0.89842;6.4382;0;0 0.90399;6.5377;0;0 0.91002;6.6074;0;0 0.91558;6.692;0;0 0.92022;6.7666;0;0 0.9244;6.8611;0;0 0.93089;6.9308;0;0 0.93599;7.0104;0;0 0.94156;7.1398;0;0 0.94573;7.1995;0;0 0.9513;7.2642;0;0 0.95872;7.4035;0;0 0.95918;7.3687;0;0 0.96429;7.4781;0;0 0.96753;7.508;0;0 0.97124;7.5826;0;0 0.97542;7.6672;0;0 0.97959;7.7318;0;0 0.9833;7.8015;0;0 0.98655;7.8761;0;0 0.98887;7.9507;0;0 0.99443;7.9856;0;0 0.99814;8.0552;0;0 1.00046;8.1199;0;0 1.00371;8.1697;0;0 1.00742;8.2144;0;0 1.0102;8.2791;0;0 1.01206;8.3288;0;0 1.01299;8.3836;0;0 ------------------------------------------------/// |
October 17, 2022, 06:19 |
Marcus Voigt
Hey,
as your error states keyword file undefined you are missing the keyword file in your velocity BC. I never tried to read a .csv for my BC. Are you sure you have to write fileName and not file? Best regards |
boundary, cfd, openfoam, profile, velocity |
Question about different kinds of Boundaries and Boundary Conditions | granzer | Main CFD Forum | 17 | April 12, 2022 17:27 |
mesh file for flow over a circular cylinder | Ardalan | Main CFD Forum | 7 | December 15, 2020 13:06 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
Problem with assigned inlet velocity profile as a boundary condition | Ozgur_ | FLUENT | 5 | August 25, 2015 04:58 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
