#0 Foam::error::printStack(Foam::Ostream&) at ??:? |
October 27, 2022, 13:04 |
Letian Jiang
Dear all
Hi everybody, I am currently trying to run a simulation with rhoPimpleFoam. My task is to perform 2D steady-state RANS simulations on a Tyrrell 026 F1 car front wing at two different wing heights of h/c = 3.36 (freestream region) , with h being the height from the ground and c being the chord length of the airfoil. The free stream Mach number is M = 0.0874 and the chord-length Reynolds number is 462000 When I tried to run rhoPimpleFoam on the case, I got the following error message: #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in /lib/x86_64-linux-gnu/libpthread.so.0 #3 Foam::hePsiThermo<Foam:siThermo, Foam:ureMixture<Foam::sutherlandTransport<Foam:: species::thermo<Foam::hConstThermo<Foam:erfectGa s<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, bool) at ??:? #4 Foam::hePsiThermo<Foam:siThermo, Foam:ureMixture<Foam::sutherlandTransport<Foam:: species::thermo<Foam::hConstThermo<Foam:erfectGa s<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct() at ??:? #5 ? at ??:? #6 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 #7 ? at ??:? Floating point exception (core dumped) I am using OpenFOAM 2.0 by the way. If you need to have a look at any of my files let me know and I will post them as soon as possible, but so far I don't really know what you are going to need. I hope you can help me. Sincerely, Marco |
