how to extract the components of radial and tangential velocities from pump impeller
Old   May 16, 2011, 21:46
Default how to extract the components of radial and tangential velocities from pump impeller
任芸
renyun0511 is on a distinguished road
hi all,
I am studying the inner flow of pump impeller by OpenFOAM-dev-1.5 with MRFSimpleFoam solver. After numerical calculation, i can extract the x,y,z components of the absolute velocity with "foamCalc components U" and i need to visualize the radial(Ur in my attachemt) and tangential (Ut in my attachment)velocities. Is there a function to extract the components of them from cartesian coordinate system? I have think it over for serval days,but i still have no ideal about it!
Thanks in advance!
jennifer
Attachment 7741
renyun0511 is offline   Reply With Quote
Old   May 17, 2011, 03:05
su_junwei's Avatar
su junwei
su_junwei is on a distinguished road
Send a message via MSN to su_junwei
Hi jennifer
I wrote a calcType for extracting Ut Ur Uz for a given velocity field several days ago. You can use it with foamCalc. If you want it, Just contact me with qq.
regards, Junwei
su_junwei is offline   Reply With Quote
Old   November 1, 2011, 22:09
Eric
tunkers is on a distinguished road
Hello Su Junwei, I am also interested in calculating Ut Ur Uz for a cartesian velocity field. Could you post the code here or send me a copy?
Best Regards, Eric
EDIT: After more searching in the forums, I found the answer to my question in the following thread:
http://www.cfd-online.com/Forums/ope...tup-error.html
Last edited by tunkers; November 3, 2011 at 22:52. Reason: Found code for velocity field conversion
tunkers is offline   Reply With Quote
Old   October 31, 2022, 09:31
Default extract Ut,Ur,Uz from Ux,Uy,Uz
Amir Amjadimanesh
amira7 is on a distinguished road
Originally Posted by su_junwei View Post
Hi jennifer
regards, Junwei
qq
Hi su_junwei
I also need to extract Ut,Ur,Uz from Ux,Uy,Uz in my flow field. would you please send your CalcType code to me too?
I would be really appreciate...
amira7 is offline   Reply With Quote
Plotting Radial Velocity and Tangential Velocity in CFD Post ashtonJ CFX 5 July 13, 2015 02:49
Radial and Tangential Velocity boundary conditions N. A. OpenFOAM 4 September 2, 2011 07:21
how to extract the components of radial and tangential velocities renyun0511 OpenFOAM Running, Solving & CFD 0 April 8, 2011 07:15
vectors in radial, tangential and axial direction mateus FLUENT 1 April 11, 2006 05:57
Radial and tangential velocity Antonio Mileo FLUENT 2 February 16, 2001 01:41
