Number of iteration difference between PCG and GAMG |
November 22, 2022, 05:52 |
HR
Rep Power: 3 |
I ran two interFOAM multiphase simulation in which one had the p_rgh solver set as PCG and one in which it was GAMG. The preconditioner for both was set to DIC. I observed that the number of iterations taken to converge to 1e-8 is higher for PCG (about 1000) and lower for GAMG (about 40). Why does this occur ?
November 22, 2022, 06:36 |
GAMG requires less iterations because it iterates on various levels of accuracy. See literature on Multigrid Methods, e.g., book of Moukalled-Darwish-Mangani or https://en.wikipedia.org/wiki/Multigrid_method.
I suggest using GAMG as preconditioner for CG to combine best of two worlds (zat least in case that number of processors is one or small). |
LES, Courant Number, Crash, Sudden | Alhasan | OpenFOAM Running, Solving & CFD | 5 | November 22, 2019 02:05 |
[solids4Foam] How to calculate drag coeff when using solids4Foam | amuzeshi | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 15 | November 7, 2019 12:50 |
Large number of iterations using PCG in pressure equation | mgg | OpenFOAM Running, Solving & CFD | 3 | January 8, 2019 02:23 |
p_rgh initial residual no change with different settings | manuc | OpenFOAM Running, Solving & CFD | 3 | June 26, 2018 15:53 |
should Courant number always be kept below 1? | wc34071209 | OpenFOAM Running, Solving & CFD | 16 | March 9, 2014 19:31 |
