Bad Pressure Distribution
Old   March 16, 2024, 13:28
Default Bad Pressure Distribution
Alan w
boffin5 is on a distinguished road
In my efforts to debug my chtmultiregion case, I finally got it to create data! Then when I went to paraView, the pressure Distibution (see attached image) has an obvious problem, with high pressure at the inlet, and low pressure at the outlet, ignoring the body in the domain.
I have been thrashing this for a couple of days, so far without luck.
It could well be that someone amongst the community has seen this problem and found a fix for it; if so, could please! share your experience with me.
File Type: png SnapCrab_NoName_2024-3-16_10-14-13_No-00.png (14.9 KB, 11 views)
boffin5 is offline   Reply With Quote
Old   March 19, 2024, 10:18
Ching Liu
qingqingliu is on a distinguished road
From my understanding, it is right if the inlet pressure is higher than the outlet
qingqingliu is offline   Reply With Quote
Old   March 19, 2024, 12:27
Default Than you qingqingliu
Alan w
Thanks for your response!
In a steady state simulation, although there may be slight pressure changes in the domain, I would expect it to be basically consistent, and show only the changes due to perturbations around the body, as shown in the attached.
However, in my problem case, there is a huge pressure change between the inlet and outlet, which cannot be right!
File Type: png SnapCrab_NoName_2024-2-29_18-7-48_No-00.png (19.8 KB, 5 views)
Old   March 19, 2024, 12:33
Ching Liu
I see, it seems that the coupling boundary between the solid region and fluid region is incorrect. Did you see a velocity gradient on the solid surface?
Suction pressure distribution at the bottom caused by a ship propeller loewieke53 OpenFOAM Running, Solving & CFD 0 April 6, 2020 06:41
outlet pressure Boundary settings -velocity streamline under ambient temp.conditions Vishnu_bharathi CFX 12 November 21, 2017 06:56
Pressure distribution Tunlu FLUENT 0 October 19, 2013 21:47
pressure distribution in water flow, differences in icoFoam and COMSOL deniggo OpenFOAM Running, Solving & CFD 14 September 30, 2010 03:48
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
