smoothSolver error when solving for P in sonicFoam |
February 6, 2023, 23:39 |
Chris Eden
I am decently new to OpenFOAM and am attempting to run a simulation of a symmetric diamond airfoil in Mach 3 STP air. When running sonicFoam I get this output: Create time Create mesh for time = 0 PIMPLE: no residual control data found. Calculations will employ 2 corrector loops Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting turbulence model type laminar Selecting laminar stress model Stokes Creating field kinetic energy K No MRF models present No finite volume options present Starting time loop Time = 1e-05 Courant Number mean: 0.527982 max: 0.579401 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 PIMPLE: iteration 1 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 3.57513e-07, No Iterations 3 smoothSolver: Solving for e, Initial residual = 1, Final residual = 9.26653e-06, No Iterations 4 smoothSolver: Solving for p, Initial residual = 1, Final residual = 2.9034e-09, No Iterations 2 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0.00801135, global = -0.00506501, cumulative = -0.00506501 PIMPLE: iteration 2 smoothSolver: Solving for Uy, Initial residual = 0.00937948, Final residual = 1.60646e-12, No Iterations 1 smoothSolver: Solving for e, Initial residual = 0.995854, Final residual = 1.47489e-08, No Iterations 1 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in /lib/x86_64-linux-gnu/libpthread.so.0 #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam:perator/(Foam::tmp<Foam::Field<double> > const&, Foam::tmp<Foam::Field<double> > const&) at ??:? #5 Foam::freestreamPressureFvPatchScalarField::update Coeffs() at ??:? #6 Foam::fvMatrix<double>::fvMatrix(Foam::GeometricFi eld<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) in /usr/bin/sonicFoam #7 Foam::tmp<Foam::fvMatrix<double> > Foam::fv:ptionList:perator()<double>(Foam::Geo metricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::word const&) in /usr/bin/sonicFoam #8 ? in /usr/bin/sonicFoam #9 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 #10 ? in /usr/bin/sonicFoam Floating point exception I am unsure of why I am getting this as I was able to solve with a different mesh and the exact same p, U, T, and controlDict files. I changed the height of my mesh in order to have the shock wave "exit" the test section. This is my blockMeshDict file: scale 1; vertices ( (0 0 -0.05) //0 (0 2 -0.05) //1 (2 2 -0.05) //2 (2 0 -0.05) //3 (0.5 1 -0.05) //4 (1 0.89 -0.05) //5 (1.5 1 -0.05) //6 (1 1.11 -0.05) //7 (0 0 0.05) //8 (0 2 0.05) //9 (2 2 0.05) //10 (2 0 0.05) //11 (0.5 1 0.05) //12 (1 0.89 0.05) //13 (1.5 1 0.05) //14 (1 1.11 0.05) //15 (2 1 0.05) //16 (2 1 -0.05) //17 (1 2 0.05) //18 (1 2 -0.05) //19 (1 0 -0.05) //20 (1 0 0.05) //21 (0.5 2 -0.05) //22 (0.5 2 0.05) //23 (0.5 0 -0.05) //24 (0.5 0 0.05) //25 (1.5 2 -0.05) //26 (1.5 2 0.05) //27 (1.5 0 -0.05) //28 (1.5 0 0.05) //29 ); blocks ( hex (0 24 22 1 8 25 23 9) (25 25 1) simpleGrading (1 1 1) hex (24 20 5 4 25 21 13 12) (25 25 1) simpleGrading (1 1 1) hex (4 7 19 22 12 15 18 23) (25 25 1) simpleGrading (1 1 1) hex (7 6 26 19 15 14 27 18) (25 25 1) simpleGrading (1 1 1) hex (20 28 6 5 21 29 14 13) (25 25 1) simpleGrading (1 1 1) hex (6 17 2 26 14 16 10 27) (25 25 1) simpleGrading (1 1 1) hex (28 3 17 6 29 11 16 14) (25 25 1) simpleGrading (1 1 1) ); edges ); boundary ( inlet { type patch; faces ( (0 8 9 1) ); } outlet { type patch; faces ( (17 2 10 16) (3 17 16 11) ); } bottom { type freestream; faces ( (0 24 25 8) (24 20 21 25) (28 29 21 20) (3 11 29 28) ); } top { type freestream; faces ( (9 23 22 1) (18 19 22 23) (18 27 26 19) (27 10 2 26) ); } obstacle { type slip; faces ( (4 12 15 7) (6 7 15 14) (12 4 5 13) (5 6 14 13) ); } ); mergePatchPairs ( ); Any help would be greatly appreciated as it is only failing on the second Pimple iteration, no matter the time step or the number of pimple iterations per time step. |
February 10, 2023, 16:44 |
Solution
Chris Eden
I solved this by breaking the inlet block into two separate blocks with a point along the leading edge of the airfoil. I believe it was creating a normal shock within the first block and causing the error as I managed to get a visualization of a solution.
chtMultiRegionSimpleFoam turbulent case | Aditya Patil | OpenFOAM Running, Solving & CFD | 6 | April 24, 2017 22:13 |
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 05:49 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
