February 13, 2023, 12:35 |
meshing killed
West Midlands
Rep Power: 3 |
I changed a few things in my meshing geometry and all of a sudden I get this error as below when I run the surfaceExtractFeature:
Create time Note: Feature line extraction only valid on closed manifold surfaces Reading surfaceFeatureExtractDict Surfaces : body.stl Output : body Load options : offset Write options: writeObj=off writeVTK=off Statistics: Triangles : 13339855 in 1 region(s) Vertices : 6669391 Bounding Box : (0.0980459 0.0999999 -6e-05) (7.1459 7.5 1.45325) Constructing feature set from included angle 150 Selecting edges based purely on geometric tests: no Killed |
[ANSYS Meshing] only automatic meshing works, | kazra | ANSYS Meshing & Geometry | 2 | February 23, 2017 11:38 |
[ICEM] Flow channel meshing problems | StefanG | ANSYS Meshing & Geometry | 19 | May 15, 2012 06:44 |
[ANSYS Meshing] Meshing strategy for External Flows | Hybrid | ANSYS Meshing & Geometry | 0 | January 24, 2012 14:27 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 11:03 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
