April 5, 2023, 04:28 |
mpirun exit code 142
mithun
I'm having trouble conducting a simulation in open foam; the simulation model is RANS k-w SST. Does anyone knows the the exit code error 142 and how to resolve the issue. (error file is given below) Time = 1 Solving for fluid region fluid0 U (0 0 0) UL (0 0 0) Re 0 alpha 0 PI1x 152.963 PI1y 0 ------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code.. Per user-direction, the job has been aborted. ------------------------------------------------------- -------------------------------------------------------------------------- mpirun detected that one or more processes exited with non-zero status, thus causing the job to be terminated. The first process to do so was: Process name: [[15418,1],1] Exit code: 142 |
April 5, 2023, 17:08 |
Ching Liu
Rep Power: 9 |
You can run without using MPI. It will show more detailed info about the error.
exitcode142, openfoam |
Non-Zero exit code of: 2 | KUAlex | CFX | 18 | April 12, 2024 07:21 |
The solver failed with a non-zero exit code of : 2 ERROR | taneradil | CFX | 1 | March 30, 2023 18:14 |
water injection error (modify the position of water injection) | wjchoi | Main CFD Forum | 0 | January 17, 2022 07:17 |
Crash with Exit code 1073741819 | Jasmina92 | ANSYS | 2 | October 23, 2018 05:33 |
The FOAM Documentation Project - SHUT-DOWN | holger_marschall | OpenFOAM | 242 | March 7, 2013 12:30 |
