April 13, 2023, 01:31 |
rhoCentralFoam crash while solving rhoE
Song Young Ik
Rep Power: 4 |
Hi, I am running rhoCentralFoam for supersonic case, and experiencing same problem about rhoE constantly.
While running solver, it crashes immediately, or after few seconds. I have tried several different ways to stabilize it (e.g. lower dt, Co) but it didn't work well When problems occur in same value everytime, it means there must be some problem to it, but I cannot find out why. What would be the problem?? Below is the error log What could be the solution?? HTML Code:
deltaT = 4.99366e-07 Mean and max Courant Numbers = 0.00269791 0.298293 Time = 4.25729e-05s diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUz, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Ux, Initial residual = 5.91172e-09, Final residual = 5.91172e-09, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 2.04788e-07, Final residual = 3.87036e-17, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 1.52285e-07, Final residual = 2.86906e-17, No Iterations 2 diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0 [38] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [38] #1 Foam::sigFpe::sigHandler(int) at ??:? [38] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" [38] #3 ? in "/lib/x86_64-linux-gnu/libm.so.6" [38] #4 Foam::hePsiThermo<Foam::psiThermo::composite, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate() at ??:? [38] #5 virtual thunk to Foam::hePsiThermo<Foam::psiThermo::composite, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct() at ??:? [38] #6 ? in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/rhoCentralFoam" [38] #7 ? in "/lib/x86_64-linux-gnu/libc.so.6" [38] #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [38] #9 ? in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/rhoCentralFoam" [songyi719sim:434738] *** Process received signal *** [songyi719sim:434738] Signal: Floating point exception (8) [songyi719sim:434738] Signal code: (-6) [songyi719sim:434738] Failing at address: 0x3e80006a232 [songyi719sim:434738] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7f1f63abd520] [songyi719sim:434738] [ 1] /lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x12c)[0x7f1f63b11a7c] [songyi719sim:434738] [ 2] /lib/x86_64-linux-gnu/libc.so.6(raise+0x16)[0x7f1f63abd476] [songyi719sim:434738] [ 3] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7f1f63abd520] [songyi719sim:434738] [ 4] /lib/x86_64-linux-gnu/libm.so.6(+0x1349c)[0x7f1f63cd649c] [songyi719sim:434738] [ 5] /opt/openfoam10/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermo9compositeENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_22sensibleInternalEnergyEEEEEEEE9calculateEv+0xe17)[0x7f1f659ba257] [songyi719sim:434738] [ 6] /opt/openfoam10/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZTv0_n64_N4Foam11hePsiThermoINS_9psiThermo9compositeENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_22sensibleInternalEnergyEEEEEEEE7correctEv+0x35)[0x7f1f659d6255] [songyi719sim:434738] [ 7] rhoCentralFoam(+0x3822d)[0x555b8ecc322d] [songyi719sim:434738] [ 8] /lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7f1f63aa4d90] [songyi719sim:434738] [ 9] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7f1f63aa4e40] [songyi719sim:434738] [10] rhoCentralFoam(+0x3a9d5)[0x555b8ecc59d5] [songyi719sim:434738] *** End of error message *** -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun noticed that process rank 38 with PID 0 on node songyi719sim exited on signal 8 (Floating point exception). -------------------------------------------------------------------------- |
April 13, 2023, 09:10 |
Song Young Ik
Rep Power: 4 |
Problem solved!
I reduced maxCo and timestep |
crash, rho, rhocentralfoam, supersonic |
chtMultiRegionSimpleFoam turbulent case | Aditya Patil | OpenFOAM Running, Solving & CFD | 6 | April 24, 2017 22:13 |
conjugate heat transfer in OpenFOAM | skuznet | OpenFOAM Running, Solving & CFD | 99 | March 16, 2017 05:07 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
