Velocity BC values for oscillatingDisplacement
Old   April 14, 2023, 14:23
Default Velocity BC values for oscillatingDisplacement
Chennakesava Kadapa
chennak is on a distinguished road
Hi OpenFOAM community,
I have a question about the velocity BCs for the case of oscillatingDisplacement boundary field.
To test, I have set up a simple case with an oscillating square with oscillatingDisplacement field with A=(0,1,0), w=6.28318. There is no other velocity field. Since the displacement is of the form "A*sin(w*t)", I expect the velocity to satisfy "A*w*cos(w*t)". However, this does not seem to be the case.
The velocity at t=0.25 should be zero but the simulation gives it as 0.197335 with dt=0.01 and 0.039486 with dt=0.002, which does not seem to match with the expected value, although it seems to converge as dt ->0.
So, I am curious to know how the velocity is calculated for moving boundaries with specified displacement.
chennak is offline   Reply With Quote
moving 3d mesh, moving boundaries
combining parabolic inlet velocity profile with time varying velocity vector values jawapasu OpenFOAM 3 July 10, 2023 05:41
serial udf to parallel udf radioss Fluent UDF and Scheme Programming 10 January 19, 2019 08:56
UDF for reading velocity values and adding random perturbation Jomid Fluent UDF and Scheme Programming 0 October 2, 2016 00:46
RMS Velocity values Firefly STAR-CCM+ 0 April 26, 2016 13:29
Z velocity contour values differ from vectors ghost82 FLUENT 0 October 7, 2012 04:23
