reactingTwoPhaseEulerFoam pressure rising into oblivion |
April 28, 2023, 09:35 |
Vinzenz Götz
Rep Power: 5 |
Hey foamers,
I am having a problem with reactingTwoPhaseEulerFoam. I want to run a pressure driven flow and for that I modified the wallBoiling tutorial. My problem here is that the pressure rises and rises in the simulation until openfoam throws an error. My p file looks like this: Code:
FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 1e5; boundaryField { inlet { /* type uniformTotalPressure; value uniform 2e5; p0 table ( (0 1.01e5) (1 1.1e5) (1.01 1.5e5) (1.1 2e5) (2 2e5)); U U.gas; psi thermo:psi.gas; gamma 1; */ type fixedValue; value 2e5; } outlet { type calculated; value $internalField; inletValue $internalField; } wall1 { type zeroGradient; value uniform 100000; } wall2 { type zeroGradient; value uniform 100000; } defaultFaces { type empty; } } Code:
boundaryField { inlet { /* type uniformTotalPressure; value uniform 2e5; p0 table ( (0 1.01e5) (1 1.1e5) (1.01 1.5e5) (1.1 2e5) (2 2e5));; gamma 1; U U.gas; psi thermo:psi.gas; */ type fixedValue; value 2e5; } outlet { type prghPressure; p $internalField; value $internalField; inletValue $internalField; } wall1 { type zeroGradient; } wall2 { type zeroGradient; } defaultFaces { type empty; } } Code:
fieldMinMax inlet_minmax write: min(T.liquid) = 259.992008 in cell 1885 at location (0.0175 1.98666667 0.095) on processor 3 max(T.liquid) = 264.538203 in cell 1707 at location (0.0475 0.0666666667 0.095) on processor 0 min(p_rgh) = 60708.731 in cell 1684 at location (0.0325 0.0133333333 0.095) on processor 0 max(p_rgh) = 319567.437 in cell 3 at location (0.0175 0.0133333333 0.005) on processor 0 min(T.gas) = 246 in cell 177 at location (0.0025 2 0.005) on processor 3 max(T.gas) = 264.167583 in cell 1707 at location (0.0475 0.0666666667 0.095) on processor 0 min(p) = 60716.7122 in cell 1684 at location (0.0325 0.0133333333 0.095) on processor 0 max(p) = 319573.132 in cell 3 at location (0.0175 0.0133333333 0.005) on processor 0 min(mag(U.gas)) = 0 in cell 0 at location (0 0.0133333333 0.005) on processor 0 max(mag(U.gas)) = 51.9675555 in cell 3 at location (0.0175 0 0.005) on processor 0 min(mag(U.liquid)) = 0 in cell 0 at location (0 0.0133333333 0.005) on processor 0 max(mag(U.liquid)) = 51.9675555 in cell 3 at location (0.0175 0 0.005) on processor 0 Code:
average(inlet) of phi.gas = -5.61329548e-06 average(inlet) of phi.liquid = -5.61329548e-06 average(outlet) of phi.gas = -1.11589869e-07 average(outlet) of phi.liquid = -0.000266711356 Thanks, Vinz |
viscosity udf don't use correct temperature and strain rate | rezvani | Fluent UDF and Scheme Programming | 8 | May 27, 2021 05:40 |
Fail to converge when solving with a fabricated solution | zizhou | FLUENT | 0 | March 22, 2021 06:33 |
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 12:23 |
How is total pressure calculated? | looee | CFX | 15 | October 30, 2019 08:14 |
Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 05:35 |
