Two phase flow, water not come out through the outlet
Old   August 1, 2023, 07:26
Default Two phase flow, water not come out through the outlet
Israel
Benny Ravid is on a distinguished road
Hello
I am trying to solve two-phase air + water flow in a straight pipe.
There are two inlets in the left side of the pipe. An air inlet and a water inlet.. There is one outlet only, for both air and water on the right side of the pipe.
The inlet air velocity is higher then inlet water velocity
When running the simulation, it seems that the water does not come out through the outlet. It looks like the water is treating the outlet like a wall.
The air does come out through the outlet
I am using Open foam Version v1912 and a solver compressedInterFoam
Guess the problem is with the Outlet boundary conditions of alpha.water and U.
The boundary conditions for outlet are:
For Alpfa.water
outlet
type inletOutlet;
inletValue uniform 0;
value uniform 0;
For U
outlet
type zeroGradient;
So how to make the water come out through the outlet.
Thanks for help.
Benny Ravid is offline   Reply With Quote
inlet, outlet, pipe, two phasw flow
Ncrit for a glider Xfoil. How to use it. GPT4 answer AlanMattanó Main CFD Forum 0 April 10, 2023 12:16
Discrete Phase Model, outlet mass flow rate does not fit edu_aero FLUENT 29 February 3, 2020 08:38
CFX siphon two phase flow - boundary conditions bolus13 CFX 18 August 25, 2016 18:39
phase change of water to water vapor by hot gas flow dhiraj.pachpande CFX 3 December 8, 2014 01:55
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
