setFields does not recognize inlet patch
Old   February 19, 2021, 06:49
Default setFields does not recognize inlet patch
Theresa
thesa is on a distinguished road
Hello everyone,
I created a mesh from a DEM of a river with snappyHexMesh. I did the spillway tutorial of openFoam and I want to apply the interFoam solver at my case. My problem is the following: in the setFieldsDict, I created a box around a part of my geometry, including the inlet patch. The setFields utility works, but it does not set the alpha values to 1 at the inlet and at the atmosphere patch , it does set the alpha values to 1 at the walls and at the internal mesh. I checked already the bounding box, it is large enough to cover the region.
defaultFieldValues
volScalarFieldValue alpha.water 0
regions
boxToCell
box (-100 -10 -10) (100 20 30);
fieldValues
volScalarFieldValue alpha.water 1
Any suggestions what might be wrong? How can I fix it?
Thank you for your replies!
regards,
Theresa
thesa is offline   Reply With Quote
Old   September 8, 2023, 16:45
Default Problem Solved?
Sarah Aguiar
Sarah_Ag is on a distinguished road
Hi, did you reach a solution? I'm having the same problem.
Sarah_Ag is offline   Reply With Quote
Old   September 11, 2023, 03:38
Tatsuya Shimizu
LongGe is on a distinguished road
Hello
When applied to "PATCH", write as follows.
see: OpenFOAM-v2212/tutorials/multiphase/interFoam/RAS/DTCHull/system/setFieldsDict
defaultFieldValues
regions
// Set cell values
// (does zerogradient on boundaries)
boxToCell
box (-999 -999 -999) (999 999 0.244);
fieldValues
// Set patch values (using ==)
boxToFace
fieldValues
Our Work: https://www.idaj.co.jp/product/ennovacfd/openfoam_gui/
Powered by Ennova : https://ennova-cfd.com/
Ennova's Channel Partners : http://www.wolfdynamics.com/
LongGe is offline   Reply With Quote
Old   September 12, 2023, 17:09
Default Had Tried
Sarah Aguiar
Hi! thanks for the reply, i set my setFields like this:
| \\ / O peration | Version: 1.3 |
| \\ / A nd | Web: http://www.openfoam.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object setFieldsDict;
defaultFieldValues
regions
boxToCell
box (-10 0 -1) (57 20 1);
fieldValues
boxToFace
box (0 0 -1) (0 20 1);
fieldValues
Then in 0 time the inlet bondary is ok! but in the follow time steps the bondary got the same problem, staying all water or partial water where should be just air. Like the pic.
Dis you saw something like this? have any tips?
Old   September 12, 2023, 18:09
Tatsuya Shimizu
Hello
What type of boundary conditions are you giving to the patch there? I mean, please indicate 0/alpha.* .
Old   September 13, 2023, 15:59
Default alpha.water
Sarah Aguiar
Thanks for the reply, this is my alpha.water
ALPHA.WATER
| \\ / O peration | Version: 1.5-dev |
| \\ / A nd | Web: http://www.OpenFOAM.org |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object alpha.water;
dimensions [0 0 0 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type waveAlpha;
waveDictName waveDict;
value uniform 0;
frontAndBack
type empty;
wall
type zeroGradient;
atmosphere
type inletOutlet;
inletValue uniform 0;
value uniform 0;
Old   September 13, 2023, 18:11
Tatsuya Shimizu
Hello
Maybe this is a "waveAlpha" problem. I don't know this type, so I can't judge if it is a bug or not.
Old   September 14, 2023, 16:58
Default Thank you
Sarah Aguiar
I'll search about this. Thank you!
inlet, interfoam, setfields, setfieldsdict, snappy hex mesh
[Other] Wedge patch '*' is not planar LilumDaru OpenFOAM Meshing & Mesh Conversion 6 January 12, 2021 05:55
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 01:47
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 13:38
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 11:25
