June 15, 2023, 05:44 |
Divergence in wave generation
Ilan
Rep Power: 7 |
Hello Foamers !
I need your help ! I am discovering the joys of wave generation with openfoam using the waveAlpha module. The thing is my calculation is starting very well. For 17 seconds, I have no problem and suddently, a very weird thing occures in the calculation a weird pressure appears for some unknown reasons. You can see the effect of this divergence on the 17th second (image). My setup is like that : wave generation as inlet wave absorbtion as outlet wall on the bottom symmetries on sides inletoutlet on top. Here are the waveProperties : Code:
upstream { alpha alpha.water; waveModel cnoidal; nPaddle 1; waveHeight 1.0; waveAngle 0.0; rampTime 3.0; activeAbsorption yes; wavePeriod 6.0; } I don't understand why this input : Code:
upstream { type waveVelocity; value uniform (1.5 0 0); } Thank you for your help ! I can provide any additional informations. Have a great day ! Magi |
September 14, 2023, 17:05 |
solution?
Sarah Aguiar
Rep Power: 2 |
Hey, did you got a solution for your problem? I'm having a simular problem.
September 19, 2023, 08:02 |
Ilan
Rep Power: 7 |
Absolutly not. I changed my subject in the mean time. But I am still interesting on knowing the reason of these divergences. Please, post the solution if you find anything !
Thanks ! |
divergence, wave absorber, wave boundary conditions, waves multiphaseinterfoam |
[IHFOAM] The IHFOAM Thread | Phicau | OpenFOAM Community Contributions | 392 | September 8, 2023 18:10 |
interFoam wave propagation and explosion of Courant number and residuals | ChiaraViola | OpenFOAM Running, Solving & CFD | 1 | June 26, 2019 05:36 |
[waves2Foam] regular wave generation attenuation | yangzhou | OpenFOAM Community Contributions | 3 | June 29, 2017 04:34 |
Deep Water Wave Generation Problem | Mahdi_co_1368 | CFX | 3 | March 11, 2015 05:23 |
Divergence problem | Smaras | FLUENT | 13 | February 21, 2013 05:03 |
